はじめに
お持ちのNintendo DS Liteの下部ケースを交換して、新品のような輝きを取り戻しましょう。
必要な工具と部品
下部ケースをDS Lite本体に固定している次のネジを外します。
4.3mmプラスネジ(ゴールド) 2本
3.9mmトライウィングネジ(黒) 1本
3.3mmプラスネジ(シルバー) 1本
5.5mmトライウィングネジ(シルバー) 3本
I cannot remove the tri-wing screws.
Zach Smith - 返信
Same to me. I tried opening the case by force. Broke several parts of the motherboard…
Leon -
I can't remove the final tri wing screw in the battery section and it looks like I grinded the screw out too much for any screwdriver to work.Is there anything I can do?
From what I know, the only solution is to drill the screw out with a very small-headed drill :/
Polaris -
作業を続ける前に、Game Pakからカバーを外します。
DS Liteの右上角付近の上下ケースの間にスパッジャーの先端を差し込みます。
DS Liteの右端に沿って注意深くスパッジャーを動かし、開口のきっかけを作ります。
上部ケースから下部ケースの大部分が外れるまで、DS Liteの裏側に沿ってスパッジャーをスライドします。
Don’t forget to remove the GBA cartridge placeholder before removing the backside
You forgot to mention to remove the battery compartment Phillips screw.
DS Lite本体から下部ケースを持ち上げて外します。
When you reassemble, make sure that you have the volume and power buttons in place, and make sure they are in the right position to line up with the switches on the motherboard. If they are not aligned, you risk snapping off the tiny switches on the motherboard (in which case, you are in for some soldering work).
I should have read the comments first - broke off the power switch because I didn't know about aligning it. No way I can do soldering, guess it's for the dustbin :-(
Emma -
Whoops, remembered the power button but forgot the volume slider.
I'll do it later.
There is no way that the fact you have to line up the volume and power switch toggles upon reassembly is not in this guide. I just carefully followed this guide to replace the shoulder buttons but ruined my DS lite because I didn’t read these (practically hidden comments due to the design of the website) comments and broke the power switch. Thankfully there are 150 million DS I can buy second hand but “repeat the steps backwards” wasn’t sufficient in this repair. And that’s what this website is for.
Ryan -
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
33 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
A Phillips #000 (PH000) seems to give a more secure fit (no slipping) than the stated Phillips #00.
Ritchie - 返信
This will be good for mods
Matthew Bevins - 返信
I'm having a problem getting the screw to unscrew. I have the right Phillips ( it was included with all the stuff I got this) Any tips. it doesn't look like the screw is spinning but i haven't played my Nintendo DS Lite for 3 years.
whittlegirls - 返信
bonjour j’ai une petite question pour vous fais trés longtemps que j’ai pas utiliser mon nintendo ds lite et quand je le branche il allume 1 fois orange après il s’enteint même s’il est brancher ça veux tu dire qu’il faut que je change de batterie ? Merci
Marie-Julie Richer - 返信
Soit un changement de batterie, soit la carte-mère a peut-être un court-circuit :/
Polaris -
