メインコンテンツにスキップ
Nintendo 3DS XL Microphone Replacement
必要な工具と部品
  1. Nintendo 3DS XL Microphone Replacement, Battery: 手順 1、 2の画像 1 Nintendo 3DS XL Microphone Replacement, Battery: 手順 1、 2の画像 2
    • Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
  2. Nintendo 3DS XL Microphone Replacement: 手順 2、 2の画像 1 Nintendo 3DS XL Microphone Replacement: 手順 2、 2の画像 2
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
  3. Nintendo 3DS XL Microphone Replacement: 手順 3、 3の画像 1 Nintendo 3DS XL Microphone Replacement: 手順 3、 3の画像 2 Nintendo 3DS XL Microphone Replacement: 手順 3、 3の画像 3
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
  4. Nintendo 3DS XL Microphone Replacement, Microphone: 手順 4、 2の画像 1 Nintendo 3DS XL Microphone Replacement, Microphone: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
  5. Nintendo 3DS XL Microphone Replacement: 手順 5、 2の画像 1 Nintendo 3DS XL Microphone Replacement: 手順 5、 2の画像 2
    • Remove the six 6.2 mm screws using a Phillips #000 screwdriver.
  6. Nintendo 3DS XL Microphone Replacement: 手順 6、 1の画像 1
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #000 screwdriver.
  7. Nintendo 3DS XL Microphone Replacement: 手順 7、 3の画像 1 Nintendo 3DS XL Microphone Replacement: 手順 7、 3の画像 2 Nintendo 3DS XL Microphone Replacement: 手順 7、 3の画像 3
    • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
  8. Nintendo 3DS XL Microphone Replacement: 手順 8、 3の画像 1 Nintendo 3DS XL Microphone Replacement: 手順 8、 3の画像 2 Nintendo 3DS XL Microphone Replacement: 手順 8、 3の画像 3
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
  9. Nintendo 3DS XL Microphone Replacement: 手順 9、 3の画像 1 Nintendo 3DS XL Microphone Replacement: 手順 9、 3の画像 2 Nintendo 3DS XL Microphone Replacement: 手順 9、 3の画像 3
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the microphone in the bottom left corner.
    • Using tweezers remove the microphone.
    • There will be a ribbon that connects the microphone to the motherboard.
  10. Nintendo 3DS XL Microphone Replacement: 手順 10、 2の画像 1 Nintendo 3DS XL Microphone Replacement: 手順 10、 2の画像 2
    • Using the flat head side of the spudger carefully lift up the flap and remove the ribbon.
    • The attached microphone can now be removed.
終わりに
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Charlene Donlon
メンバー登録日: 04/08/14
10,343 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 9-13, Regan Spring 2014 Cal Poly, Team 9-13, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S9G13
5 メンバー
44のガイドは作成済み
2 件のコメント
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
Melissa Cardenas - 返信
please learn to repair the mic of new 3ds xl
andrew.hws - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 36
過去 30 日: 142
今までの合計 11,162
