メインコンテンツにスキップ
Nintendo 3DS XL Left Bumper Replacement
必要な工具と部品
  1. Nintendo 3DS XL Left Bumper Replacement, Left Bumper: 手順 1、 1の画像 1
    • Remove the SD card and the game cartridge from the device.
  2. Nintendo 3DS XL Left Bumper Replacement, Battery removal: 手順 2、 2の画像 1 Nintendo 3DS XL Left Bumper Replacement, Battery removal: 手順 2、 2の画像 2
    • Locate the battery cover panel on the back of the device.
    • Unscrew the two screws on the battery cover panel with a Phillips #00 screwdriver.
    • Remove the battery and battery cover panel.
  3. Nintendo 3DS XL Left Bumper Replacement: 手順 3、 1の画像 1
    • Remove the four screws on the battery panel using the Phillips #00 screwdriver.
  4. Nintendo 3DS XL Left Bumper Replacement: 手順 4、 1の画像 1
    • Locate the two screw covers on the bottom of the back panel, near the middle of the device.
    • These sticker-like covers are small, round, and made of rubber or plastic.
    • Insert the tip of a flathead screwdriver or spudger and gently pry the cover off by applying upward pressure.
    • You may need to wiggle the tool back and forth a bit to loosen the two covers.
    • Remove the two screws located behind the screw covers using a Phillips #00 screwdriver.
  5. Nintendo 3DS XL Left Bumper Replacement: 手順 5、 2の画像 1 Nintendo 3DS XL Left Bumper Replacement: 手順 5、 2の画像 2
    • Remove the screw near the game card compartment using a Phillips #00 screwdriver.
  6. Nintendo 3DS XL Left Bumper Replacement: 手順 6、 2の画像 1 Nintendo 3DS XL Left Bumper Replacement: 手順 6、 2の画像 2
    • Lift the back panel off of the device.
    • Be cautious not to pull any ribbons or cables from the motherboard as you remove the back panel.
    • Locate and disconnect the ribbon cables from the motherboard by gently pulling on the tabs that hold them in place.
  7. Nintendo 3DS XL Left Bumper Replacement: 手順 7、 2の画像 1 Nintendo 3DS XL Left Bumper Replacement: 手順 7、 2の画像 2
    • Remove the three left bumper assembly screws using Phillips #00 screwdriver.
    • Once the three screws are removed, gently remove the left bumper assembly from the device.
    • The spring may eject from the assembly as you remove it.
    • Remove the hinge pin from the bumper assembly.
  8. Nintendo 3DS XL Left Bumper Replacement: 手順 8、 1の画像 1
    • Separate the bumper from the bumper assembly
  9. Nintendo 3DS XL Left Bumper Replacement: 手順 9、 2の画像 1 Nintendo 3DS XL Left Bumper Replacement: 手順 9、 2の画像 2
    この手順で使用する道具:
    Microfiber Cleaning Cloths
    $3.99
    購入する
    • Using a spudger or a flathead screwdriver, gently pull the ribbon cable straight out of the connector in order to remove it.
    • The ribbon cable can be removed by other means such as using gloves or a microfiber cloth if preferred.
    • Replace the left bumper ribbon cable.
終わりに
2 の人々がこのガイドを完成させました。
作成者
13人の作成者と共同で作成されました。
Jack Belcher
メンバー登録日: 10/26/21
187 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 3-1, Thomas Fall 2021 University of North Texas, Team 3-1, Thomas Fall 2021人のメンバー
UNT-THOMAS-F21S3G1
4 メンバー
3のガイドは作成済み
3 件のコメント
No steps on how to install the new bumper?
Alex Tomalty - 返信
good but i wish there were reinstall instructions
Rowan Webb - 返信
I think that it's just basically do the steps backwards then you have it fixed.
Ender - 返信
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 44
過去 30 日: 222
今までの合計 5,067
