はじめに
The guide will help take apart the Nintendo 3DS XL to uncover the motherboard, then identify the IR Board in order to be replaced.
必要な工具と部品
Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
Hold the device so that the cover is facing up.
Using a plastic opening tool, pry off the cover starting at the top right corner.
Hold the edge of the cover to ensure it does not reattach.
Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
Take off the cover of the device and set it aside.
Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
Position the device such that the game cartridge slot is located at the top.
Locate the IR board located on the upper right side of the motherboard.
Remove the IR board with a plastic opening tool by inserting the tool below the IR board and gently prying up.
11 の人々がこのガイドを完成させました。
4 件のコメント
This guide was really helpful, I had to teardown my 3DS to remove a rice crispy that was stuck in the SD card reader, I don't know how it got there, I wasn't even eating cereals
was removing the analog stick really necessary?
8bitlooser - 返信
So I have an original 3DS and a 3DS XL the 3DS Xl Works great but the 3DS won't turn on. I believe it is because I t has a missing IR Board. I am hoping to use the one on the 3DS XL. Do you think it will work?they look similar in the pictures..... Anyway I am confused as to why I have to take out the cirlepad??
AppleTopic - 返信
if you are missing ir board the system will not boot?
