はじめに
So you managed to break your circle pad and can't play your favorite games? Don't fear, the circle pad can be replaced!
必要な工具と部品
Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
Hold the device so that the cover is facing up.
Using a plastic opening tool, pry off the cover starting at the top right corner.
Hold the edge of the cover to ensure it does not reattach.
Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
Take off the cover of the device and set it aside.
Note that on the lower side (opposite to the hinges), there are small hooking tabs. These require you to lift the top (screw side) off towards you, then the lower area.
Insert the plastic opening tool into the opening located on the right side of the battery.
Pry off the battery from the lower casing.
Lift the battery out of the case and set aside.
My 👴 grandpa was helping me 🔧 repair my 3ds xl and ⚡️electrocuted himself with the 🔋battery while we was taking it out with a 🔪 knife. 💀 Rip grandpa 😔
Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
I found that the rubber bumps don't move easily, you'll likely have to use a lot of upward force to move them.
jconnell85 - 返信
I torn one of the bumpers because I used a needle instead.
You do have a pry a bit. I tore one a little but not that big of a deal.
try twisting upward
Kmi Nguyen - 返信
My 3DS XL is so old that the rubber bumpers were very hard to remove.
So I tried to heat the rubber bumpers a little bit with a hair dryer for 15-20 seconds, with some pauses every 5 seconds in order to avoid overheating or damaging something as a precaution.
It worked well to remove them but the only drawback is that as my rubber bumpers already got damaged and scratched because of my previous attempts without heating first, heating it up after aggravated the scratch damages when I used tweezers.
So I would recommend heating the rubber bumpers moderately first and be gentle when using something that could scratch or damage them.
(Do not take my words for it, it may not work for you)
S. Tony Ly - 返信
I was able to remove mine that were being very difficult with some dull tweezers. I used dull ones because I didn't want to scratch anything. First I wedged it between the plastic and the bumper, wiggled it a tiny bit, pulled it out, wedged it again in another spot and continued this until I got it out with my fingernail. Neither the bumper nor my shell were damaged.
Remove the six 6.2 mm screws using a Phillips #00 screwdriver
#000 ifixit philips screwdriver does not fit the 6.2mm screws. Whats the deal?
I have a 000 Phillips from tekton and it worked just fine.
Megan -
I stripped a good #000 screwdriver, and found that EVERY screw actually fit perfect and snug with a #00 screwdriver. Zero damage to the screws or the screwdriver with the #00.
I bought and used the #00 screwdriver, and it worked perfectly for this.
I had also bought the #000, but I never needed it during the entire operation.
jconnell85 - 返信
All 6 screws are exactly the same so you don't have to worry about mixing them up.
One of the screws in my 3ds XL seems to have its '+' engraving worn off, i can't seem to unscrew it, though the other 5 unscrewed properly. What should I do?
Potato Man - 返信
I stripped a screw in my 3ds xl and don’t know how to get it out. Do I have to use a drill or is there another way?
Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #00 screwdriver.
between these two steps, the bottom two screws are not mentioned. make sure to take those out too ;)
Make sure the SD card has been removed. With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
Make sure that you have removed your SD card, otherwise that'll keep you from completing this step.
jconnell85 - 返信
Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
Completely remove the lower case from the rest of the device and set aside.
Thank you so much for pointing that out, it was keeping my system from starting up and I thought I blew it!
Yup, that is definitely an upside-down IR board, and will result in a silent post error. It was driving me crazy trying to figure out why the system wouldn't start up.
That's it!! Thanks so much!! I've tinkered around about one month and couldn't get this thing to work...all because I've followed the guide here and looked the picture up twice so I don't put the IR-Board in the wrong way...
Thank you guys so much! I followed everything faithfully and it was DOA on startup. (Black screens, blue light). The IR board was backwards. These pictures need to be fixed. As-is, it shows a broken 3DS.
You should always work on the device in a 3/4 open position- this allows the ribbon cables to have slack and will less likely tear, and is the only position the hinge pin can be removed or installed as it is keyed
Position the device such that the game cartridge slot is located at the top.
Locate the circle pad on the right side of the device.
Remove the two 7.5 mm screws on the upper left and the bottom right corners.
Careful you don’t lose the little washer on the circle pad stem. It’s not held down by anything.
Using a plastic opening tool pop off the circle pad joystick.
Do not use excessive force with the plastic opening tool. There is a ribbon attaching the circle pad joystick to the motherboard that will remain attached.
I found it easy to put my finger ontop of the board and apply a little pressure. When i popped off the board, my finger stopped it flying off.
I made a small mistake by popping the circle pad joystick and it went flying off and now im stuck trying to put it back in
Using the flat head side of the spudger carefully lift up the retaining flap that attaches the circle pad ribbon to the motherboard.
Remove the ribbon and circle pad joystick.
The 'flat head' holds it in place when down, and you can reattach your ribbon cable when it's up, it only needs to be partway in so when you close the flat head, if your joystick board can't move easily in place then you've done it right, it it's too loose, try again to work the ribbon cable under.
jconnell85 - 返信
The ribbon goes into the left side of the "flat head" right? Not the end that clamps down on the right? I'm having a !&&* of a time sliding the end of the ribbon into the little space between the flat head when it's up and the side of the terminal.
For those of you like me, who got stuck after the last step.
To understand how to actually remove the circle pad, continue with these steps at 21.
Hope it helps those after me. I almost ripped some cabling inside thinking I had to take out the motherboard.. luckily I didn't.
Just as what monk333y said, follow the Original 3DS steps. They are identical and you don't have to remove anymore big parts. The only annoying part is taking out the circle pad.
I broke the retaining clip. It is not very strong and I used a bit too much force i think in opening the clip or pushing it back down. Thinking of using hot glue or something else to keep the circle pad ribbon in place.
Did the hot glue work? I did the exact same thing now im not sure what to do…
When testing the touchscreen, make sure you install the analog. Otherwise, the screen will act erratic. Thought I broke a brand new part. Just a heads up!
The entire top part of my circle pad had broken off, so I had no problem getting the old one out. I actually had more trouble getting the ribbon cable back into the clip, and the new circle pad attached to the stick, than any other part.
That said, this was way, way easier than I expected it to be.
96 の人々がこのガイドを完成させました。
28 件のコメント
Thank you very much.Perfect repair the circle pad.
The circle pad link:http://www.ebay.com/itm/Genuine-New-Anal...?
mouyi chen - 返信
Great guide, just upgraded my joystick. Bought my replacement from shapeways. The replacement is metal so it won't break like the last one. Also it's a lot more comfortable.
Anyway highly recommend this replacement:
I'm having trouble removing the plastic case in step 7, it seems it refuses to come apart at the SD card part. What should I do? What is holding it down?
Remove the SD card
My son broke the circle pad on his 3DS XL while playing Super Smash Bros.. I purchased 2 circle pads just in-case from http://www.ebay.com/itm/Genuine-New-Anal...
Excellent replacement, just like the original circle pad. The write-up and pics were very helpful. Highly recommend for anyone needing to buy and replace the circle button on a 3DS XL.
When removing the circle pad joystick in Step 10, my ribbon came off of the piece that is attached to the motherboard. I tried attaching it back and turned my 3DSXL back on and the connection was making the select tool jump sporadically on my screen without me moving the circle pad at all. Is this fixable or do I need to send my 3DSXL to Nintendo?
http://m.ebay.com/itm?itemId=19159304393...
I received my circle pad from this seller.
You need to remove the SD card before step 7. I was struggling to flip the back cover until I realized the SD card was in the way. Instructions otherwise were excellent.
It takes very little prying to take off the back plate and back cover once the screws are off. If you have to force it you are probably doing it wrong.
This Screwdriver is too big for the screws in mine. Maybe it's a later model or something, but keep that in mind.
I'm having trouble with the first two screws and I'm using the right screwdriver. The right turned easily but I'm having trouble with the left. No matter how I turn it it won't budge I think I've ruined the screw. What can I do to turn it or fix this?
Well a small but large enough problem is that there are 2 variation for 3ds XL circle pad and the screws will not aligned unless it is screwed into it self.
Couldn't get the ribbon for the joystick back on and the plastic retaining flap broke as I applied pressure. Should have sent it to the pros. Also the guide doesn't say what to do to actually install the joystick. Otherwise useful until that point, bit bummed that I destroyed my 3ds despite being very careful.
Just registered to add my thanks for this - absolutely brilliantly easy guide to follow which has (together with replacement circle pad for $2 on ebay) made our son extremely happy to have his 3DS back again! Thanks!
Thanks. A well-organised guide, very good pictures, and every step explained.
BUT
For a guide headed "Circle Pad Replacement" it completely fails to show how to actually replace the circle pad! (Which is why *we are all here*!)
Luckily I flicked across to another guide that gave me the clues I actually needed. (quiet "yay!")
Two more points:
1) There is no instruction advising us to remove the SD card. Would have helped (a lot).
2) With all the covers off, and while turning it over to insert the circle-pad, it is possible for some parts to simply drop out. The little corner thingies for attaching a carry/safety strap. Not essential to its function, sure. But still. That info could have helped me. (I found it on the carpet five minutes after I thought I had finished.)
Cheers
G
My battery won't charge after doing this... Please help
My ribbon cable tab came undone, I have used 5 others and cant seem to get it on, I have used sticky tape to connect it but doesn't connect properly what do I do, I am very frustrated at this point.
Hi there,
I just used this walkthrough to replace just the outer pad tip/top (brushed steel from Shapeways.com), not the whole module. While your instructions were very helpful for the steps involved in opening the case, you might want to adjust them to say that a 1.5 mm cross head works best to avoid stripping the tiny screws, instead of a pointy #000 Phillips head. Also, if you're just replacing the outer pad, you don't really have to do step 11 (and disconnect the module thingy entirely from the board) - all you have to do is pull the broken "joystick pad" part out of the hole once you unscrew the module, open the DS carefully from below (so as not to lose parts from the underside), twist the replacement pad into place, making sure to include the washer you mentioned around its base (between it and the casing), then close the DS again, pop the module connected to the board back onto the underside of the "joystick pad", then screw it back down, insert the battery and SD card, and close up the casing.
do i need to replace the circle pad ribbon?
Why didn’t you include the most important last step of this: DO NOT REMOVE THE RETAINING CLIP THAT HOLDS THE CIRCLE PAD RIBBON IN PLACE. SLIDE THE OLD RIBBON OUT AND SPLIP THE NEW ONE IN, THEN CLOSE THE CLIP. Thanks to leaving out this very important detail, we have to buy a new circuit board. That clip is impossible to put back and there’s no way to get that ribbon to stay in place without it.
excellent guide, I broke my circle pad playing terraria and after months of delivery of wether to do it myself of pay to fix it I find the guts to do it. your guide turn the scales on my favor, really easy to follow and even better ilustrated.
My joystick was sticking and refusing to move in the “down” direction. Wiggling it to try and fix it the joystick broke at the top as well. The washer was cracked underneath (original problem) and beyond repair. I need to order the replacement joystick but I’ll also need a new washer; as it was fairly flimsy and the pieces fell apart after the joystick top broke off I don’t have even a cracked one to take in to any shop… can someone point me to where I’d find a comparable (or better) replacement washer?
Not that it was too hard to figure out, but there seems to be a final step missing - the actual plastic thumb stick has a C shaped thin film washer which needs removing with tweezers, after which the stick can be carefully removed by twisting the underside so that one edge works its way to the surface side of the case, and then turning around it works the rest of it loose.
I followed the guide, which was extremely helpful, and replaced the joystick. But now it does not recognize up and down, only side to side. I took it back apart to ensure the ribbon cable was fully secured, and it was, so I’m at a loss for what could be wrong. Does anyone have any ideas?
Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again!
justjustintuber - 返信
what type screwdriver do i use?!? its so small!!!!
Matthew - 返信
I had success using a #00 Phillips head
Jake S -
Can't clip the front of the back cover back in
Macro Man - 返信
I had trouble too, but got past it by slipping the bottom edge into the three indents first then easing the rest of the cover on!
Issu -
I found these were actually #00
Demosthien - 返信
The screws in the 1st picture are stripped. What screwdriver head do I use?
Adric101 - 返信
