メインコンテンツにスキップ
Nintendo 3DS XL Battery Replacement
必要な工具と部品
  1. Nintendo 3DS XL Battery Replacement, Battery: 手順 1、 2の画像 1 Nintendo 3DS XL Battery Replacement, Battery: 手順 1、 2の画像 2
    • Loosen the two #0 Phillips 4.2 mm-length screws located at the top of the back cover.
    • The screws have locking washers that prevent the screws from falling off of the back cover. Leave these locking washers on the screws; it is not necessary to remove the washers for this repair guide.
    Note: If your top or bottom screen was working before disassembly and doesn't work after reassembly, then it's likely that the connector is loose or dirty or damaged or not clipped or PLACED UPSIDE-DOWN. I had this issue with my Super3DS XL(2015) and it turns out that the reason why my top screen wasn't working after put together, was because I had the top LCD connector upside-down. After I correctly put the connector in, It worked again!
    justjustintuber - 返信
    what type screwdriver do i use?!? its so small!!!!
    Matthew - 返信
    I had success using a #00 Phillips head
    Jake S -
    Can't clip the front of the back cover back in
    Macro Man - 返信
    I had trouble too, but got past it by slipping the bottom edge into the three indents first then easing the rest of the cover on!
    Issu -
    I found these were actually #00
    Demosthien - 返信
    The screws in the 1st picture are stripped. What screwdriver head do I use?
    Adric101 - 返信
  2. Nintendo 3DS XL Battery Replacement: 手順 2、 2の画像 1 Nintendo 3DS XL Battery Replacement: 手順 2、 2の画像 2
    • Hold the device so that the cover is facing up.
    • Using a plastic opening tool, pry off the cover starting at the top right corner.
    • Hold the edge of the cover to ensure it does not reattach.
    • Look for the small section below the stylus compartment. Pry off the cover at that point if it is still attached.
    • Take off the cover of the device and set it aside.
    Note that on the lower side (opposite to the hinges), there are small hooking tabs. These require you to lift the top (screw side) off towards you, then the lower area.
    Jordan Kelly - 返信
  3. Nintendo 3DS XL Battery Replacement: 手順 3、 3の画像 1 Nintendo 3DS XL Battery Replacement: 手順 3、 3の画像 2 Nintendo 3DS XL Battery Replacement: 手順 3、 3の画像 3
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry off the battery from the lower casing.
    • Lift the battery out of the case and set aside.
    My 👴 grandpa was helping me 🔧 repair my 3ds xl and ⚡️electrocuted himself with the 🔋battery while we was taking it out with a 🔪 knife. 💀 Rip grandpa 😔
    Corban Bennett - 返信
終わりに
42 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Charlene Donlon
メンバー登録日: 04/08/14
10,215 ポイント
8のガイドは作成済み
チーム
Cal Poly, Team 9-13, Regan Spring 2014 Cal Poly, Team 9-13, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S9G13
5 メンバー
44のガイドは作成済み
5 件のコメント
Time estimate: 3 - 9 hours Difficulty: Very difficult ??????
More like 30-90 seconds, and that's if you have to search for a screwdriver.
Tommy Lynch - 返信
机器无法开机怎么办?是电池的问题吗?
doanaruto - 返信
It should be noted that the bottom three clips on the bottom of the backplate can’t just be snapped in, they need to be slipped in, so when removing the backplate, it should be tiled away from the system and then pulled up from the bottom, and those three clips on the bottom should be the first clips in when you’re putting it back together, sliding them in with the backplate at an angle, and then the rest of the clips just snap in.
Cole Jackson - 返信
Just did this. For reasmbly I recommend putting the bottom/lower part of the case on first before you screw it back on.
Scott Vogel - 返信
コメントを追加
統計データ:
過去 24時間: 32
過去 7 日: 230
過去 30 日: 1,066
今までの合計 49,511
