メインコンテンツにスキップ
Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement
必要な工具と部品
  1. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement, Battery: 手順 1、 1の画像 1
    • Ensure your device is powered off before proceeding. Failure to do so may result in electrical shock or damage to the device.
    • Place the 3DS upside down. Remove the game card, headphones, charging cable, stylus, or anything else that may be connected to the device.
  2. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 2、 1の画像 1
    • Using a JIS #0 screwdriver, loosen the two black screws on the back.
    • The screws are held in place by captive washers and should not be completely removed.
  3. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 3、 1の画像 1
    • Once the screws are loosened, pry open the back cover.
  4. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 4、 1の画像 1
    • The battery is located on the left hand side of the 3DS - to remove, use the small gap located at the top-middle and pull up with a non metal pointed tool.
  5. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement, A,B,X,Y, Start or Select Button: 手順 5、 1の画像 1
    • Remove six 6mm screws on secondary panel using a JIS #000 screwdriver.
  6. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 6、 2の画像 1 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 6、 2の画像 2
    • Remove two upper rubber bumpers locates on either side of the charging port.
    • Using JIS #00 screwdriver, carefully remove the two 6mm screws that have now been exposed.
  7. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 7、 3の画像 1 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 7、 3の画像 2 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 7、 3の画像 3
    • To pry off the cover, carefully lift it up and away from the hinges (in order to clear the headphone port), then pivot it towards the hinges to expose the circuit boards.
  8. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 8、 1の画像 1
    • Use non-conductive tweezers to disconnect the two ribbon plugs that connect the L/R/ZL/ZR buttons on the cover to the motherboard, then remove it completely.
  9. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 9、 3の画像 1 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 9、 3の画像 2 Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 9、 3の画像 3
    • Locate the ribbon connector between the motherboard and the left circuit board (it should be the widest) and use a pair of tweezers to pivot up the ZIF clasp upward.
    • The ribbon can be removed using non-conductive tweezers by pulling out parallel with the board.
  10. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 10、 1の画像 1
    • Next, locate the five 3mm screws on the left board and remove them using a JIS #000 screwdriver.
  11. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 11、 1の画像 1
    • Carefully flip the board over and use tweezers to remove the blue-black ribbon located underneath.
  12. Nintendo 3DS XL 2015 A,B,X,Y, Start or Select Button Replacement: 手順 12、 1の画像 1
    • Remove the gray rubber diamond to reveal the A/B/X/Y buttons and/or the rubber rectangle to reveal the Start/Select button.
    • Remove the buttons using tweezers.
    • When replacing, be sure to check that each button is placed back and is snugly fit into the appropriate hole before reassembling the device.
終わりに
24 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Kobbe Farwick
メンバー登録日: 04/01/15
2,124 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 24-4, Lancaster Spring 2015 Cal Poly, Team 24-4, Lancaster Spring 2015人のメンバー
CPSU-LANCASTER-S15S24G4
4 メンバー
25のガイドは作成済み
10 件のコメント
do the smaller new 3ds colored buttons work in the new 3ds xl?
itsandy14 - 返信
It will work, since the only difference between them is the size of screen and shell, but size of buttons and other pieces should be of the same.
CheatJoker -
If anyone else comes on this, I can confirm the small 3ds buttons do not quite work right they are slightly smaller and the cut outs that keep the buttons from spinning around are not the same
Mark Damien English -
Can someone provide further information about replacement of the entire C stick?
Or is it just as simple as pull the ribbon carefully, take the old one out and put the new one in?
CheatJoker - 返信
The set of screws on the secondary panel are giving me trouble. I think I might be stripping them... Is it normal for them to be screwed on so tight? I don't want to pay 85 bucks just because I need to press my B button harder to make it work...
Ben Fuqua - 返信
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 113
過去 30 日: 523
今までの合計 37,363
