はじめに
マザーボードの交換は最後に残された方法です。取り出す際はご注意ください!
必要な工具と部品
JIS #0ドライバーを使って、裏面の黒いネジ2本を緩めます。
My experience indicates that a JIS #1 is more appropriate here.
Same here, much more appropriate.
バッテリーは3DSの左側にあります。取り外すには、上部中央にある小さな隙間を使い、先の尖っていないでツールで押し出します。
Also you should remove any SD card at this point
Does this battery work on a NEW 3DS XL model?
This guide is for the New 3DS XL, which is called the 2015 3DS XL here on iFixit. If you're asking about the 3DS replacement battery advertised in the iFixit store, I believe it works for both new and old models.
JIS #000ドライバーを使って、補助カバーの端沿い付近に留められている6mmネジを6本外します。
I used a #00 instead it works better for a model form 2016
remove the micro Sd card or the shell wont come off and damage the Sd card reader and the connecter
ピンセットを使って、3DSの上部端に留められたラバーバンパーを慎重に外します。これを取り出すと、2本の6mmネジが出てきます。JIS #000ドライバーを使って外します。
Can the rubber bumpers be replaced once you reassemble the 3DS? I'd really hate to have to take them out and never be able to put them back in, if I'm honest...
Yep, we were able to put them back in quite easily after repeated teardowns! If they ever refused to stay in for some reason, you could always put a little bit of something sticky on them. (I use scrapbooking tape on my laptop's bumpers.)
What happens if I strip one of these screws? How hard would into be to remove them?
very hard. i stripped 4 screws on my new 3ds xl and i haven’t been able to get them out. i even bought the precision screw extrator set and nothing the set sucked.
カバーを外すには、慎重にヒンジから持ち上げて取り外します。(ヘッドホンポートを外すため)それから、ヒンジ側に向けてカバーをテコのように持ち上げて、回路基板を露出させます。
I accidentally opened it and broke the ribbon cable to the r and zr buttons by accident. How do I fix it?
You have to replace the whole thing.
ピンセットを使って、L/R/ZL/ZR ボタンリボンをマザーボードに引っ掛けている2つのプラグを持ち上げて外します。これでバックカバーを外せます。外したら脇に保管してください。
I discovered that there is enough clearance to slide the Game Cartridge Slot assembly out without removing the motherboard. Just remove the two connectors going to the Cartridge Slot assembly and take out the 3 screws holding it down. There were two screws that look like they are holding the assembly down, but they are only holes through the assembly and don’t actually hold it down. At least on the Pokemon version, New 3DS XL that I had.
Can confirm, it's leagues easier to do it that way than to go to the trouble of removing the entire motherboard, potentially screwing something up in the process. Thank you so much for sharing this alternative method!
I third this alternative method for D-pad replacement. To add to the previously noted detail, you also need to disconnect a 3rd connector going to the Cartridge Slot assembly, the one going to the D-pad Board itself which is underneath the Cartridge Slot assembly, which is shown at a later step in this guide. Also, I found I needed to loosen the two screws on the motherboard located nearest the Cartridge Slot assembly in order to get enough clearance to slide the assembly out, as there are two plastic guide stands that hold the assembly in place which the motherboard otherwise holds too tightly to pass. Otherwise, incredibly smooth sailing, minimal connectors removed, and my New 3DS LL import model finally has a working left/right again. Thanks everyone!
ピンセットで小さなヒンジ付きロックフラップを持ち上げ、サークルパッドリボンを固定しているZIF コネクタ のロックを解除します。
ZIFコネクタからリボンケーブルをスライドして外します。
Is not the right side, the switch must be pull to the left, otherwise people will brake it.
DartzSoryu - 返信
I suggest removing the joystick first, swing to left side, then lift up on ZIF connector from the right. You’re able to pull ribbon cable out easier from the left at that point w/o breaking it, as I did.
2nd the removing of the joystick first via the two screws and to be careful handling the plastic washer underneath. It’s coated with a Teflon type material to aid in stick movement. also use a finger nail over tweezers any change you get. A nail is less rigid with natural give and less likely to break plastic latches. If it doesn’t open from the end you expect, stop, and try the other side right away. Be gently.
マザーボードの左上にある、赤色のケーブルが付いたゴールドの端子プラグを探します。指を使って、慎重にプラグを上向きに引き抜いて外します。
ピンセットを使って、1つのリボンコネクタの接続を外します。
MDR j'avais vu cette erreur il y a un petit moment... et vous pouvez ajouter, ne pas casser le connecteur comme sur la photo !
ピンセットを使って、マザーボードの淵に沿って付いている5箇所のリボンケーブルをZIFコネクタから引き抜きます。
リボンコネクタには、プラスチックの留め金付きフラップが付いており、ズレ防止にリボンを覆っています。ピンセットを使って、リボンを取り出す前にフラップを持ち上げてください。
Hi,
Can you pls inform me the purpose of the topmost red marked ZIF transparent flex cable, I wish to repair my N3DS XL but I am missing this flex cable (for which part is this cable relevant).
Thanks
I don't have the model on me for reference, but if I remember correctly, it's for the bottom screen.
I think it should be noted that the upper most ZIF is incorrectly labelled here as one to remove with tweezers and not to try to open the clamp. I did this recently and have now broken my brand new 3ds. This cable is for the digitizer at the front of the bottom screen. So my touch screen no longer works. I now need to carry out a further repair. Just a heads up.
Accurate. I have to purchase a new digitizer because of this. I tore the conductors in the cable removing it from the ZIF connector. And I’m really very angry that no correction has been made in the almost 9 months since you posted.
Sabs Like Labs, can you please share a picture of your connector ? last time I dismounted one I had no problems with this connector but maby there are different versions ?
Zoe, I don’t suppose you would know what part to search for to replace one of these lock-less friction connectors? Before this article posted I partially broke one of mine thinking it had a lock and would like to replace it. The old one still works but I have to fiddle with it to get a good connection now. The one I broke is nearest to the cartridge socket.
&&^& all those tutoriel now is just break my new 3ds &&^& you internet
I broke my connectors the little gray pieces broke not the touch screen and the joy stick are broken.
I can confirm there are two different versions of the clip. One flips up and just pushes in
As others have mentioned, the topmost red connector HAS A CLAMP that you need to flip up. It seems like the creator of this guide has a 3ds with older board revision. With multiple people already having brought up the issue, the creator should absolutely update this guide to note the differences as others have already broken their devices due to this guide.
Can confirm that the top most connector has a clamp on mine as well. tore the ribbon cable taking it out and now my bottom screen touch screen is unresponsive. also if you are on this guide looking to replace the game card reader, i also found out after trying to replace mine … You DO NOT need to remove the motherboard in order to replace it !
Then digitizer absolutely should be updated to note, I also broke the GREY clamp off, when treying to remove, and bought a new one.
I believe this to be the replacement https://www.amazon.com/dp/B078WQY7N9?psc...
I also ruined the digitizer connector thinking it had a lock (yes, I failed to read the guide correctly). I ordered another motherboard that cost me $100 (ifixit had none in stock, only option on ebay) only to find out it still doesn't work (now for some reason no button nor touchscreen work which doesn't even make sense since they all have different connectors). Please update this guide to point people to just remove the card reader without taking the motherboard off. I could have avoided all this by just replacing the card reader directly.
Wow...ifixit is flat out lying about that top connector. There is no such thing as 2 different board revisions. ALL models have the clamp type connector. If you zoom in you can clearly see the creator has broken off the clamp in the pictures and is misrepresenting it as a friction connector. Unbelievable.
マザーボードの下側にある、さらに2つのZIFコネクタにアクセスするために、ヒンジ側に向けて、マザーボードを直角に回転させます。
どちらのコネクタにもラッチが付いておりこれを持ち上げてはずさなければなりません。左側のより長いラッチは黒色で、右側の短いラッチは白色です。フラップを持ち上げて、ボタンをスライドして外し、マザーボードを取り出します。
9-15 aren't necessary at all. Its a super easy fix step 16 is sufficient.
I think you might be confused; this is a guide for replacing the motherboard, not the entire bottom half of the unit.
The top says this is a guide for the directional pad though
Jimmy -
Oh! Apologies; I didn't realize iFixit duplicated comments for duplicate steps. The message alert directed me to the motherboard replacement guide. Whoops.
Anyway, as I recall, the card reader was more safely and easily removed once the motherboard was out of the way. But I agree that it was likely doable without. Thank you for the input!
Getting the ribbons back in can be a challenge but don’t give up. Pull them taught and try to work at an angle that give you the most length.
Do you know the name of the shorter zif connector, or how to order it? I am talking about the one that is on the botton side of the board,that sometime it is hard to connect the ribbon cable. I think it has like 30 pins. Thank you.
What is the name or how to order the small zif connectors that is on the bottom side of the board, I think it has like 30 pins. Thank you
I just want to swap out lcd screens, what steps can I omit? this is the only bottom screen guide online and so many bricks wtf can’t someone make a video like top lcds there are many.
Update about the commentaries above :
If your goal is to replace something in the top part of the console, steps 9-15 are still necessary as all of the components up there travel through the R hinge to connect to the main board.
- Top screen and Audio/3D cable connect to the back of the motherboard shown at step 15 (screen is the left one shown on the illustration).
- Camera bar connects to the front of the motherboard (step 13, shown as the up-and-rightmost orange connector)
- Wifi antenna connects to the antenna connector (step 12), probably the easiest to replace without disconnecting the motherboard since it doesn't involve rolling up and threading a flat cable through the hinge.
このデバイスを再組み立てするには、インストラクションを逆の順番に従って作業を進めてください。
47 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
11 件のコメント
With some digging, I managed to find this on the GBAtemp forums , which host a community of 3DS modders:
https://gbatemp.net/threads/screwed-up-p...
Seems like no one's quite sure, but it could be a start. Unfortunately, the N3DS components are largely small black boxes with no labeling.
If you have a multimeter, it might help to test some of these mystery boxes.
Question: Seeing as how you pulled the red cable in the photos, how was that fixed? Asking for a friend.
We...never fixed that actually, as we didn't have the tools for it and the device had been loaned to us specifically for tearing down.
I don't know if iFixit themselves ever did anything with it, but I would imagine soldering the frayed end of the cable back onto the plug would work. (Here's a guide on that: http://www.instructables.com/id/Solderin... )
You mean the model? This is the "New" Nintendo 3DS XL.
For reference, you can check the model number (MOD) on the back. The 3DS models are numbered as follows:
* CTR-001: Nintendo 3DS
* SPR-001: Nintendo 3DS XL
* KTR-001: "New" Nintendo 3DS
* RED-001: "New" Nintendo 3DS XL
Is the prices in USD
Hello, i’m sorry, i don’t know the answere for this. I imagine that replacing the motherboard can affect the update version but i can’t see why it wouldnt be upgradable to the newest versions.
I have a question? Will a regular new 3ds xl mother bard like this one https://www.ebay.com/itm/2015-New-3DS-XL... would work for my galaxy style new nintendo 3ds xl? Will this motherboard work? Please answer
It would work.
oof -
The picture of tweezers is great as a pointing tool but I prefer to use a finger nail whenever possible. With a finger nail you can get the perfect amount of leverage on a latch and it’s spread over a greater length of the lever. I’ve broken a few plastic latches early on with with tweezers and prefer to avoid them now.
