メインコンテンツにスキップ
Nintendo 3DS SD Board Replacement
必要な工具と部品
  1. Nintendo 3DS SD Board Replacement, Back Cover: 手順 1、 1の画像 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS SD Board Replacement: 手順 2、 2の画像 1 Nintendo 3DS SD Board Replacement: 手順 2、 2の画像 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS SD Board Replacement, Battery: 手順 3、 3の画像 1 Nintendo 3DS SD Board Replacement, Battery: 手順 3、 3の画像 2 Nintendo 3DS SD Board Replacement, Battery: 手順 3、 3の画像 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS SD Board Replacement, Lower Case: 手順 4、 1の画像 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS SD Board Replacement: 手順 5、 3の画像 1 Nintendo 3DS SD Board Replacement: 手順 5、 3の画像 2 Nintendo 3DS SD Board Replacement: 手順 5、 3の画像 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS SD Board Replacement, SD Board: 手順 6、 1の画像 1
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  7. Nintendo 3DS SD Board Replacement: 手順 7、 2の画像 1 Nintendo 3DS SD Board Replacement: 手順 7、 2の画像 2
    • The connector for the SD board sits underneath the Circle Pad ribbon cable.
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  8. Nintendo 3DS SD Board Replacement: 手順 8、 3の画像 1 Nintendo 3DS SD Board Replacement: 手順 8、 3の画像 2 Nintendo 3DS SD Board Replacement: 手順 8、 3の画像 3
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Run the spudger along the sides of the SD board to free it from the adhesive pad holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
終わりに
21 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
David Hodson
メンバー登録日: 04/13/10
150,467 ポイント
127のガイドは作成済み
7 件のコメント
Where can i purchase the sd card board replacement part? Does amazon carry them?
Jen - 返信
You can usually find them on ebay to around $3 to $6 dollars (non oem and oem)
David Vokas -
Is there a way to do this with the older 3ds xl version? I didn't see any screws holding the sd board in when I opened it up.
NickySeley - 返信
Would this work for my problem? My problem is that the SD Card won't stay in, it just pops back out. Would this method still work? I'm not that experienced or knowledgeable about fixing these sort of things, so I'm not sure if the spring is part of it or not, lol. Also, where could I buy an SD Card board replacement part for cheap in Canada?
Caitlin Lumsden - 返信
Usually that is the locking mechanism, you can replace the SD card slot for around $6 or $3 if you buy the non oem part.
David Vokas -
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 62
過去 30 日: 234
今までの合計 28,140
