メインコンテンツにスキップ
Nintendo 3DS Motherboard Assembly Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
必要な工具と部品
  1. Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: 手順 1、 2の画像 1 Nintendo 3DS Motherboard Assembly Replacement, Motherboard Assembly: 手順 1、 2の画像 2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  2. Nintendo 3DS Motherboard Assembly Replacement: 手順 2、 3の画像 1 Nintendo 3DS Motherboard Assembly Replacement: 手順 2、 3の画像 2 Nintendo 3DS Motherboard Assembly Replacement: 手順 2、 3の画像 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  3. Nintendo 3DS Motherboard Assembly Replacement: 手順 3、 2の画像 1 Nintendo 3DS Motherboard Assembly Replacement: 手順 3、 2の画像 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  4. Nintendo 3DS Motherboard Assembly Replacement: 手順 4、 3の画像 1 Nintendo 3DS Motherboard Assembly Replacement: 手順 4、 3の画像 2 Nintendo 3DS Motherboard Assembly Replacement: 手順 4、 3の画像 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  5. Nintendo 3DS Motherboard Assembly Replacement: 手順 5、 3の画像 1 Nintendo 3DS Motherboard Assembly Replacement: 手順 5、 3の画像 2 Nintendo 3DS Motherboard Assembly Replacement: 手順 5、 3の画像 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
  6. Nintendo 3DS Motherboard Assembly Replacement: 手順 6、 1の画像 1
    • Remove the motherboard assembly from the rest of the device.
終わりに
作成者
6人の作成者と共同で作成されました。
David Hodson
メンバー登録日: 04/13/10
150,500 ポイント
127のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,578
