メインコンテンツにスキップ
Nintendo 3DS Lower Case Replacement
必要な工具と部品
  1. Nintendo 3DS Lower Case Replacement, Back Cover: 手順 1、 1の画像 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Lower Case Replacement: 手順 2、 2の画像 1 Nintendo 3DS Lower Case Replacement: 手順 2、 2の画像 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Lower Case Replacement, Battery: 手順 3、 3の画像 1 Nintendo 3DS Lower Case Replacement, Battery: 手順 3、 3の画像 2 Nintendo 3DS Lower Case Replacement, Battery: 手順 3、 3の画像 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Lower Case Replacement, Lower Case: 手順 4、 1の画像 1
    • Remove the nine 6.3 mm black Phillips screws from the lower case.
    • These screws will strip very easily unless you use the correct size bit. Apply pressure to the screws while turning to avoid stripping them.
    • Remove the 2.4 mm silver Phillips screw above the game cartridge slot.
  5. Nintendo 3DS Lower Case Replacement: 手順 5、 3の画像 1 Nintendo 3DS Lower Case Replacement: 手順 5、 3の画像 2 Nintendo 3DS Lower Case Replacement: 手順 5、 3の画像 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
終わりに
7 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
David Hodson
メンバー登録日: 04/13/10
150,503 ポイント
127のガイドは作成済み
2 件のコメント
Is this guide for the original 3ds?
Glenn Racz - 返信
yessir it is
Electronik -
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 34
過去 30 日: 121
今までの合計 15,706
