はじめに
This is a step-by-step guide on replacing the cartridge (game card) reader so you can get back to enjoying playing those nostalgic games on the go! This guide is only applicable to the original Nintendo 3DS model. Other guides are available to help you replace the cartridge slot on other 3DS/2DS models.
必要な工具と部品
Use a JIS #00 screwdriver to loosen the four screws along the top of the back cover. These screws stay in the cover after loosing them.
Remove all 10 screws to access the third layer and the motherboard of the 3DS. Don't forget the one near the game card slot, it is silver, not black.
To remove the cartridge reader look for 4 solder joints, 2 on each side of the reader (see image).
Apply heat to them with a soldering iron to melt the solder and take out the reader. Use a spudger to lift the reader out of the board as you apply heat.
You can apply some solder flux or even some new solder wire to form an alloy between the old and new metals, this would ease the task.
Now that the game cartridge reader is out, let's get the new one in. Make sure to correctly line it up with the previous one and re-solder it using a soldering iron and solder.
Before reassembling the device use isopropyl alcohol and a cotton swab and clean the surrounding area, removing all of the remaining flux residue.
After cleaning, you can reassemble your device.
