メインコンテンツにスキップ
Nintendo 3DS Battery Replacement
必要な工具と部品
  1. Nintendo 3DS Battery Replacement, Back Cover: 手順 1、 1の画像 1
    • Unscrew the four Phillips #00 screws along the top of the back cover.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    • The comments section is full of unlucky souls who will tell you that the screws here through step 4 will strip incredibly easily. Press down fairly hard, and go slow.
  2. Nintendo 3DS Battery Replacement: 手順 2、 2の画像 1 Nintendo 3DS Battery Replacement: 手順 2、 2の画像 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Battery Replacement, Battery: 手順 3、 3の画像 1 Nintendo 3DS Battery Replacement, Battery: 手順 3、 3の画像 2 Nintendo 3DS Battery Replacement, Battery: 手順 3、 3の画像 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
終わりに
45 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
David Hodson
メンバー登録日: 04/13/10
150,493 ポイント
127のガイドは作成済み
7 件のコメント
Where do you buy a new battery from for your nintendo 3ds?
Midori Neko - 返信
Amazon or eBay are your friend!
Also Nintendo store sells it
Alberto -
Easy as pie. Thanks for writing this guide!
3DRepairMan - 返信
I want to buy a battery to replace the old one, do you have any stablishment in An Salvador where I can buy it?
wilfredo_montesm - 返信
https://store.nintendo.com/battery-pack-... Here it is for the 3ds and 2ds battery pack from Nintendo.
Nelson Berrios - 返信
コメントを追加
統計データ:
過去 24時間: 58
過去 7 日: 475
過去 30 日: 2,189
今までの合計 67,654
