メインコンテンツにスキップ
Nintendo 3DS 2015 D Pad Replacement
必要な工具と部品
  1. Nintendo 3DS 2015 D Pad Replacement, Battery: 手順 1、 1の画像 1
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 D Pad Replacement: 手順 2、 2の画像 1 Nintendo 3DS 2015 D Pad Replacement: 手順 2、 2の画像 2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 D Pad Replacement: 手順 3、 3の画像 1 Nintendo 3DS 2015 D Pad Replacement: 手順 3、 3の画像 2 Nintendo 3DS 2015 D Pad Replacement: 手順 3、 3の画像 3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 D Pad Replacement, SD Card Reader: 手順 4、 1の画像 1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
  5. Nintendo 3DS 2015 D Pad Replacement: 手順 5、 1の画像 1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 D Pad Replacement: 手順 6、 2の画像 1 Nintendo 3DS 2015 D Pad Replacement: 手順 6、 2の画像 2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
  7. Nintendo 3DS 2015 D Pad Replacement, Lower Case: 手順 7、 3の画像 1 Nintendo 3DS 2015 D Pad Replacement, Lower Case: 手順 7、 3の画像 2 Nintendo 3DS 2015 D Pad Replacement, Lower Case: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 D Pad Replacement: 手順 8、 2の画像 1 Nintendo 3DS 2015 D Pad Replacement: 手順 8、 2の画像 2
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 D Pad Replacement: 手順 9、 3の画像 1 Nintendo 3DS 2015 D Pad Replacement: 手順 9、 3の画像 2 Nintendo 3DS 2015 D Pad Replacement: 手順 9、 3の画像 3
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 D Pad Replacement, Gamecard Reader: 手順 10、 2の画像 1 Nintendo 3DS 2015 D Pad Replacement, Gamecard Reader: 手順 10、 2の画像 2
    • Locate the gamecard reader near the bottom right corner of the motherboard.
    • Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
    • Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
  11. Nintendo 3DS 2015 D Pad Replacement: 手順 11、 2の画像 1 Nintendo 3DS 2015 D Pad Replacement: 手順 11、 2の画像 2
    • Pry the ribbon cable from its socket, just left of the joystick, using the flat side of a spudger.
    • Grab the right edge of the gamecard reader and lift it out of the device, watching to make sure the ribbon cables don't snag.
  12. Nintendo 3DS 2015 D Pad Replacement, D Pad: 手順 12、 2の画像 1 Nintendo 3DS 2015 D Pad Replacement, D Pad: 手順 12、 2の画像 2
    • Remove the four 3mm Phillips #00 screws from the four corners of the D pad board.
    • Lift the D pad board out of the device.
  13. Nintendo 3DS 2015 D Pad Replacement: 手順 13、 2の画像 1 Nintendo 3DS 2015 D Pad Replacement: 手順 13、 2の画像 2
    この手順で使用する道具:
    • Peel the rubber piece, backing the D pad, out of the device.
    • Lift the D pad out of the device with a pair of tweezers.
終わりに
作成者
2人の作成者と共同で作成されました。
Tyler Starr
メンバー登録日: 10/06/16
1,639 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S4G6
4 メンバー
35のガイドは作成済み
4 件のコメント
I think you missed a few steps after step 9. There is no mention of removing the 3DS Cartridge reader or Circle Pad.
jharris - 返信
Jharris is right
Birby B. - 返信
Thanks for pointing that out! I think it is fixed now.
-Tyler
Tyler Starr -
My new 3DS d-pad is stuck in the up direction, what could be the problem?
Flute_Boi - 返信
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 54
過去 30 日: 151
今までの合計 4,205
