メインコンテンツにスキップ
Nintendo 3DS 2015 Battery Replacement
必要な工具と部品
  1. Nintendo 3DS 2015 Battery Replacement, Battery: 手順 1、 1の画像 1
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 Battery Replacement: 手順 2、 2の画像 1 Nintendo 3DS 2015 Battery Replacement: 手順 2、 2の画像 2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 Battery Replacement: 手順 3、 3の画像 1 Nintendo 3DS 2015 Battery Replacement: 手順 3、 3の画像 2 Nintendo 3DS 2015 Battery Replacement: 手順 3、 3の画像 3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
終わりに
6 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Tyler Starr
メンバー登録日: 10/06/16
1,639 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016人のメンバー
CPSU-LIVINGSTON-F16S4G6
4 メンバー
35のガイドは作成済み
5 件のコメント
The link to the Nintendo store to buy a battery no longer functions.
David Clarke - 返信
My console has been off and without a battery for months now and I haven't been able to get a replacement battery until very recently, I replaced it just now and the orange led lights on (albeit for a short time) but the console won't turn on. The blue led lights up briefly then goes out again and the console remains off. Could it be something wrong with the console itself rather than the battery? Edit: Should I just leave it plugged in for a while even if the orange led doesn't stay on?
Leon J - 返信
I solved it by cleaning the contacts, reseating the battery and removing the microSD card. The SD card can then be put back in later
Leon J -
How's the battery life on it so far? I know you just posted 2 days ago, but I was just curious.
Will Reds -
i bought one of these batteries but it’s slightly smaller than the original battery and and the charge does not last long, maybe 1-2 hours
Jessica V - 返信
コメントを追加
統計データ:
過去 24時間: 22
過去 7 日: 93
過去 30 日: 297
今までの合計 7,706
