メインコンテンツにスキップ
Nintendo 3DSの音量スイッチの交換
必要な工具と部品
  1. Nintendo 3DSの音量スイッチの交換, バックカバー: 手順 1、 1の画像 1
    • バックカバー上部の#00プラスネジ4本を外します。
    • ネジは脱落防止ワッシャーで固定されているので、バックカバーから抜けることはありません。
    • コメント欄は、ネジは手順4を通じて信じられないほど容易に舐めてしまうといった不運の声で溢れています。ネジを回すときは、かなり力を入れ、押しながらゆっくり回してください。
    #00 screwdriver is too big... probably need a #000
    thomascroguennec - 返信
    #00 will work - but you must press down firmly and sort of jerk the screw out a few degrees at a time. If you don't press firmly, the screws strip very easily. Using #000 will strip the screws more easily.
    Tai -
    I used a #0 without any issues and 0 stripped. I used the #0 for all screws internally and externally. The head was sharp and I applied adequate amounts of pressure when loosening the screw.
    Ben Kevan -
    The correct screwdriver should be a JIS, or you can get a screwdriver specific for the 3DS from other sites for less than $2
    Oscar - 返信
    do you have to buy it
    deeznuts -
    Where would I buy a screwdriver specifically for the 3DS? Also would it work on the DS? I need to replace the battery for my DS.
    Caitlin Lumsden -
    I used Phillips #000 and it worked like a charm, i need to order a new SD board or do you guys think i should send it. What happened is that it got water damaged and everything works fine when i opened it everything looked fine no signs of water corrosion everything on the 3DS works exept it always give me a message saying the SD card is locked and i know for a fact it isnt locked i already tried using 3 different SD cards and none of them are lock protected and yes they are formatted as well. I need help
    Leo Torres - 返信
    there's a switch on the SD card, switch it and it will be unlocked again. it happened to me once too.
    Bagel -
    david hodson you are incredible. literally all you need to do is heat the screen up and pry it off and you make them take apart the whole thing
    melody - 返信
    You've done this?
    magykmaster -
    I have to ask the same question. If just the glass display is broken, and you're heating it up to remove the glass, is it really necessary to remove everything? Doesn't like like it is necessary
    Wade -
    I just did it your way and it went fine. didnt even have to remove the battery. This is incredible misstep on the authors part.
    patrick -
    only take out the screen for a motherboard removal? Are you using the wrong guide or was this guide used for two different repairs?
    Reed Deemer -
    I used a PH0x50, but it wasn't easy.
    John - 返信
    This may be a dumb question but where do I buy the 3DS upper screen?
    John - 返信
    eBay... Just do a search for the 3DS Upper screen. $9.49 & it comes with the tools.
    Gary Darnell -
    The LCD screen I ordered came with all the tools I needed except a pair of tweezers. All in all it was about $14.00 and a little bit of my time.
    Gary Darnell - 返信
    Does anyone know where I can find the right bumper button for a 3ds? I can't find it on ebay must of damaged it playing smash bros.
    Steven Castro Parrilla - 返信
    Really wish I had read the comments first... How about instead of the warning saying to press down hardly and go slow, you say to use the correct screwdriver size like others mentioned in the comments. I not only stripped multiple screws, even after putting a glove on for more pressure, I bent my screwdriver from pressing down so hard. Granted it's a cheap jeweler's kit screwdriver, but it still would've been nice to not have that problem and be informed of the right size in the first place.
    hockeymorgan35 - 返信
    Got my tools one day after ordering, as I live a couple hours away from the supplier, Will post again when i try guide.
    nintendokakashi - 返信
    I tried doing this with a #00 Philips but it just didn't turn
    Acrobatic Mars01 - 返信
    Hello there, I need some assistance I have done a full housing replacement I have everything working except the 3d slider . The 3D option is always on can someone let me know which flex it is or what I am forgetting . Thanks guys !
    Noe Ibarra - 返信
    The 3D light lets you know there is a 3D option available for the current game you’re playing. Usually, it is always on, except when you’re playing a game that doesn’t support 3D. Turning the 3D slider off does not turn off the 3D LED.
    Scott D -
    I've always been lucky with these four, and at the time it was my first disassembly so I didn't know what stripping a screw was!
    FarmYard Gaming - 返信
    These screws don't strip easily, however, the screws at step 4 do.
    TheBlueInkling -
  2. Nintendo 3DSの音量スイッチの交換: 手順 2、 2の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 2、 2の画像 2
    • 片手でデバイスを掴み、裏返します。
    • カバーが元の位置に戻らないようにもう片方の手でバックカバーの上端を掴みます。
    • バックカバーが表になるようもう一度3DSを裏返します。
    • バックカバーを引き上げ、デバイス本体から取り外します。
    Rember to transfer the model number sticker to the new cover
    Caleb Mezenberg (Caleb) - 返信
  3. Nintendo 3DSの音量スイッチの交換, バッテリー: 手順 3、 3の画像 1 Nintendo 3DSの音量スイッチの交換, バッテリー: 手順 3、 3の画像 2 Nintendo 3DSの音量スイッチの交換, バッテリー: 手順 3、 3の画像 3
    • バッテリーと底部ケースの隙間にプラスチックの開口ツールを差し込みます。
    • プラスチック製開口ツールを使って、バッテリーを持ち上げます。
    • バッテリー上部の端をつかみ、底部ケースから持ち上げます。
  4. Nintendo 3DSの音量スイッチの交換, 底部ケース: 手順 4、 1の画像 1
    • 底部ケースから黒の6.3mmプラスネジを9本外します。
    • ゲームカートリッジのスロットから銀の2.4mmプラスネジを外します。
    Had to give up at this point. Tried using the ifixit #00 phillips screwdriver to take out two screws and ended up stripping them.
    Demios - 返信
    Stuck at the same spot, those screws are in there really tight.
    John Pasula - 返信
    Ruined my screws because of incorrect head, thanks!
    3dsuser - 返信
    I had so much trouble with these screws, I gave up. Unfortunately, I can't accept failure so tried again. I figured out if you turn it right before you loosen it worked. Maybe it was just me, but I turned it right then kept pressure as I turned to loosen. I was surprised I hadn't stripped any screws out.
    Nicole Bauer - 返信
    Does anyone have any idea of how to remove these screws. I've pretty badly stripped the screws and I've gone to 20+ pages trying to figure this. I'm considering just prying the !@#$ thing.
    Vino - 返信
    use a dremil and make it a flat head
    Ralph Prowant -
    ruined my screws here too...what the !@#$ nintendo?
    trying to survive a nuclear meltdown inside the !@#$ thing
    Hamza Jarkas - 返信
    More like trying to subtly enforce planned obsolescence by not allowing you to make repairs to your device.
    Ullyssys -
    I used a #00 Philips 1/8" bit with no problem; however, the narrow diameter of the counter sunk hole can inhibit making secure contact with the screw head. You can be using the right bit (#00) but if the diameter of the bit shaft is too big you won't get proper contact.
    I found this to be an excellent guide. Thanks
    Dave W - 返信
    Unscrewed the nine 6.3 mm screws using the J000 bit from the iFixit 54 bit driver kit without much effort & without stripping the screw heads. Just gotta really position the bit correctly on the screw to have a proper fitting & not strip the screw heads.
    STZ9 - 返信
    The screws didn't strip but the philips screw driver did? @__@
    These are rough either way.
    John Zhou - 返信
    I used a "Whia 273 - PH000x40" screwdriver and held it firmly pushing the palm of my hand on the yellow end of the screwdriver and rocked the screw slightly (counter clockwise and clockwise) until it started to move. Then, without letting up on the pressure I carefully backed it out. The screwdriver is excellent because it is hardened (unlike some cheapo's out there) and the very tip is blunt not sharp. If the tip is too sharp, the point will bottom out in the screw and the sides that do all the work, won't be able to fully contact the inside of the screw. This screwdriver fits so well that the screws actually stick to it once they are removed. If the screwdriver moves AT ALL when you initially try it in the screw, STOP and find a better one. Also, start with the screws in the center, somehow they seem a little easier until you get the feel for it.
    Paul -
    Push down hard and turn counter-clockwise, or push down and rotate 3DS counter-clockwise until screw is loose.
    Jonathan - 返信
    Had the exact same problem, even tried the #000 screw driver too. Stripped the screws due to how tightly they are screwed in there and how easy they strip. I am now unsure what to do from here or if all I can do is give up.
    Sean Baldwin - 返信
    I second the one who suggested the Whia 273 PH000x40 screwdriver. I had a terrible time unscrewing these screws, and almost stripped them using a cheaper #000 screwdriver. Also tried a 3/16" flathead and destroyed the screwdriver. I bought the Whia and glad I did. It fit perfectly and did not slip at all. DEFINITELY recommend purchasing this high-quality screwdriver. Cost about $10 but well worth it to avoid the hassle.
    pbrazis - 返信
    The best way I found that works quite well, if you find a screwdriver or bit that is good enough: hold the screwdriver or bit with tons of pressure, and rotate the 3DS clockwise! It will come out in 5-6 rotations, you can do this step in about 10 minutes this way (put down a cloth first, don't scratch the front!)
    Gannon Trueman - 返信
    I HAVE A WAY TO GET OUT THE STRIPED SCREW. Like you, I had screwed up and tried everything to get the screw out. Do NOT try the glue in that tiny hole, you will get the screw glued permanently in there. The rubber band doesn't work in that tight space either. As desperate as I was, I was trying anything from nail polish to cramming the screw driver in as hard as I possible could. Until I realized that I had a drill. Yes, with the smallest head, I drilled into the screw a little bit, messed with the part I was trying to get out, drilled a little more, messed around, and then finally on my last attempt, I had successfully drilled off the top of the screw rendering the part free. It doesn't matter which drill you use as long as you can fit the head into the hole. Then drill forward like you are trying to drill a hole through wood. Now the only problem is that the remainder of the screw will be stuck in its place. All you really have to do is get a set of pliers and twist that puppy out. And there you go!
    YuuChan - 返信
    Most likely though, if you have all the other screws out and only have one striped screw, the part should just pop off and you wouldn't have to drill the entire head off the screw.
    YuuChan - 返信
    Got a brand new #00 screw drive and it striped the first time used it. So now I'm using eyeglass repair kit screw driver and it lasts longer that the one I got of of eBay.
    And I tried all of those tactics that people have been giving and none of them are working.
    The wiha 273 PH #000×40 unsrews it easily! It has a magnet on it!
    Najee - 返信
    I’m cant get these %#*@ screws out i want to die…
    FRØSTBIT3 - 返信
    Oh god, someone help i can’t get them out.
    Mark LaPierre - 返信
    omg everyone is struggling in here smh. I used my PH000 screwdriver made sure it went in aligned to the screws and applied pressure while turning counterclockwise. once it started the screw started lifting i stopped applying pressure and they lifted beautifully. saved damaging my screws with this technique. I also used the same screwdriver size to remove the orange screw where the game slot is. Yall are welcome lol
    Evelyn Avalos - 返信
    USE A DIFFERENT SCREWDRIVER.
    I was stuck on this for an hour. If your screwdriver is very thin, you won't get the grip necessary if your screws are on tight. I thought my screws were stripped but I switched to a bigger screwdriver and it was effortless. Just MAKE SURE IT IS A 00 PHILLIPS HEAD.
    brendon - 返信
    Use a JIS screwdriver, not Phillips! I bought the recommended screwdriver from this website and couldn't remove any screws. I went and purchased a J00 screwdriver and removed them quickly.
    danielle - 返信
    I used what I believe is a 1.5mm screwdriver which I received in one of those 60 in 1 precision screwdriver sets. It fit perfectly and much more snugly compared to any of the J0 - J000 bits.
    Andrew - 返信
    You should change the Screwdriver Type used. A Philipshead can damage Screws and/or Console. Use JIS Type-J00, which iFixIt sells, yes.
    J022 - 返信
  5. Nintendo 3DSの音量スイッチの交換: 手順 5、 3の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 5、 3の画像 2 Nintendo 3DSの音量スイッチの交換: 手順 5、 3の画像 3
    • 3DSの他の部分から底部ケースの下端を持ち上げて外します。
    • 2本のリボンケーブルがまだマザーボードをケースに接続しているので、底部ケースを完全に引き離さないようにしてください。
    • プラスチック製開口ツールを使い、マザーボード上のソケットからショルダーボタンのリボンケーブルを取り外します。
    • デバイスから底部ケースを取り外します。
    When assembling, make sure that L ribbon is inside the case and R ribbon is not under the aluminium battery case. I got them both cut accidentally and had to replace :(
    Marek Jakóbiak - 返信
    Man muss die Folienkabel für die Tasten nicht unbedingt abziehen wenn man einen Gegenstand dahinter stellt, an dem man den Deckel senkrecht anlehnen kann.
    Jean - 返信
    Don't listen to the german guy. It's very easy to pop back
    Bruno N - 返信
  6. Nintendo 3DSの音量スイッチの交換, スライドパッドジョイスティック: 手順 6、 1の画像 1
    • スライドパッドの裏をマザーボードに固定している7.7mmプラスネジを2本外します。
    my screws wont stop spining what to i do? i have the same problem with other screws and this leavs my joystick very loss and it is dificult to muve it becuase it is aganst the case not lifted up? any sugestions? (sorry for my bad speling jaja im very bad at speling..)
    AppleTopic - 返信
    I think you stripped your screws. I think the best solution is to change the upper cover of the lower assembly and the screws. The fastest, but temporarily is to stick in some way the joystick housing to the cover, but it won’t last long, so do this only if you have to use your console while you wait the cover to come. Anyway, so not overtighten the new screws, or you will be in the same situation once again.
    Daniele Carminati -
  7. Nintendo 3DSの音量スイッチの交換: 手順 7、 3の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 7、 3の画像 2 Nintendo 3DSの音量スイッチの交換: 手順 7、 3の画像 3
    • スパッジャーの平面側先端を使って、マザーボードからスライドパッドの裏面を持ち上げて外します。
    • マザーボードからスライドパッドジョイスティックを持ち上げて、リボンケーブルコネクタにアクセスできるよう裏面を下にして置きます。
    When reassembling verify that the circle pad control is oriented right. I had to go back in after completion when I realized it wasn't centered.
    Daniel Johnson - 返信
    I would not disable the back side all the way because it could really mess up your 3DS.
    masterspeggy3 - 返信
    From this step, follow this video https://youtu.be/XGdRim2Mvrk?t=627
    you can skipp from step 8 to 20
    lots of unnecessary steps
    Bruno N - 返信
  8. Nintendo 3DSの音量スイッチの交換: 手順 8、 3の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 8、 3の画像 2 Nintendo 3DSの音量スイッチの交換: 手順 8、 3の画像 3
    • スパッジャーの平面側先端や指の爪を使って、スライドパッドリボンケーブルのZIFソケットの固定フラップを跳ね上げます。
    • ソケットではなく、蝶番で動く固定フラップのみを跳ね上げているか確認してください。
    • マザーボードからスライドパッドジョイスティックを持ち上げて外します。
    Can you replace a zif socket? The little metal pieces on mine broke off...
    Colton Alverson - 返信
    YOUR &&^&@@ HAHAHAAHA, no you cant you would have to purchase a new motherboard i feek you bro happened in my first time
    vrobinson -
    you might want to find someone who is skilled in component level microsoldering for that
    Samuel Martin -
    The retaining flap on mine broke off, is there any way to fix it?
    Madi Hansen - 返信
    Don't do this step! it is not necessary. you can skip steps 8 through 20
    S Maduras - 返信
    Skip steps 8 through 20. It will save a lot of time. Thanks S Maduras for the warning.
    clarissa.vetintegral - 返信
    Thanks S Maduras! Your tip
    made this super easy. No need for steps 8-20.
    Carl Vero -
    OH MY GOD THANK YOU SO MUCH!!!! I'm sure I would have destroyed my ds if I did all that
    Amber Selley -
    Just like everyone else I recommend skipping to step 21. You don't need to take all the components out to replace the circle pad.
    Callum M. - 返信
    Skip steps 8-20 like they said!! Doing all those unnecessary steps wasted so so much time and frustrated me hugely by causing me to damage my microphone ribbon cable…
    Falcon - 返信
    What do you mean by skipping 8-20? Do I not need to remove the screws in order to replace the lower LCD?
    Marion Saga -
    you know, after you disconnect the ribbon from the mobo, you can just remove the back discs and the rubber part. no need to go past here.
    TruGoose - 返信
  9. Nintendo 3DSの音量スイッチの交換: 手順 9、 2の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 9、 2の画像 2
    • 作業中、スライドパッドジョイスティックの下についている2つの薄いパッドを紛失しないように、ここで取り出します。
    • スパッジャーやドライバーを使って、デバイスからパッドを持ち上げて外します。
    When reassembling, you can use the pointy end of the spudger to align the hold again with the joystick. It’ll probably have bounced around while you’re moving other things.
    anthonyhersey - 返信
    If your only goal is to replace the circle-pad, the following steps are unnecessary. You can skip to step 21, the removal of the circle-pad.
    Andrew - 返信
  10. Nintendo 3DSの音量スイッチの交換, SDボード: 手順 10、 1の画像 1
    • SDボードをマザーボードに固定している4.5mmプラスネジを2本外します。
  11. Nintendo 3DSの音量スイッチの交換: 手順 11、 2の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 11、 2の画像 2
    • スパッジャーの平面の先端を使い、SDボードのリボンケーブルのコネクタをマザーボードのソケットからてこの原理で取り外します。
  12. Nintendo 3DSの音量スイッチの交換: 手順 12、 3の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 12、 3の画像 2 Nintendo 3DSの音量スイッチの交換: 手順 12、 3の画像 3
    • SDボードとマザーボードの隙間にスパッジャーの平面側先端を差し込みます。
    • SDボードの側面に沿って、スパッジャーを動かし、SDボードを留めている接着パッドを剥がします。
    • 一度完全に剥がされたら、マザーボードからSDボードを垂直に持ち上げて外します。
    be careful on this step, the sd card board is adhered to the rf shield below it, and bay result in the shield becoming bent as it is only soldered on one side. pry from the side of the board facing the cartridge slot.
    alex chargeer - 返信
    I didnt notice that and I broke the solders here :(
    Tony Greco -
    mine came off will this make the system not power on or make somthing not work? what do i do know?
    AppleTopic - 返信
    What did come off? the sd card reader board, or the shield mentioned in the above comment?
    Daniele Carminati -
    When putting it all back together, its easier to put the ribbon connector on before laying on the SD board.
    Pepper - 返信
  13. Nintendo 3DSの音量スイッチの交換, Wi-Fiボード: 手順 13、 2の画像 1 Nintendo 3DSの音量スイッチの交換, Wi-Fiボード: 手順 13、 2の画像 2
    • Wi-Fiボードの角の下にスパッジャーの平面側の先端をスライドさせ、Wi-Fiボードをマザーボードから持ち上げます。
    • Wi-FiアンテナケーブルがWi-Fiボードにまだ接続されているので、Wi-Fiボードを完全に取り外すことはまだできません。
  14. Nintendo 3DSの音量スイッチの交換: 手順 14、 3の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 14、 3の画像 2 Nintendo 3DSの音量スイッチの交換: 手順 14、 3の画像 3
    • マザーボードからWi-Fiボードを持ち上げて、底部が上向きになるまで回転させます。
    • スパッジャーの平面側先端を使い、Wi-FiボードのソケットからWi-Fiアンテナケーブルのコネクタを外します。
    • デバイスからWi-Fiボードを取り外します。
    That moment you bought all your supplies and realise while removing the wifi chip the antenna is not plugged in because you forgot to plug it in last time……… Scew me…
    Sidney the wolf - 返信
  15. Nintendo 3DSの音量スイッチの交換, マザーボードアセンブリ: 手順 15、 2の画像 1 Nintendo 3DSの音量スイッチの交換, マザーボードアセンブリ: 手順 15、 2の画像 2
    • マイクのそばにあるマイクのリボンケーブルをピンセットでつまみます。
    • マイクを上部ケースから垂直に引き上げます。
  16. Nintendo 3DSの音量スイッチの交換: 手順 16、 3の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 16、 3の画像 2 Nintendo 3DSの音量スイッチの交換: 手順 16、 3の画像 3
    • スパッジャーの平面側先端や指の爪を使って、スピーカーアセンブリのリボンケーブルのZIFソケット上の固定フラップを跳ね上げます。
    • ソケットではなく、蝶番で動く固定フラップのみを跳ね上げているか確認してください。ソケットやケーブルを損傷させると、電源ボタンを押したときに電源LEDが点滅するだけになってしまいます。ご注意ください。
    • ピンセットを使って、スピーカーアセンブリのリボンケーブルの接続を外します。
    Can there be a guide on how to replace this part? I pry on the socket accidentally.
    im just a Ordinary marker - 返信
    I don't even know where they sell a new socket for this, but you'd need to have a soldering station and know how to micro solder. assuming no pads where ripped off then you'd just solder it back down. if a pad broke then you'd need to run jumpers to fix it. in short its very difficult and expensive to fix unless you have the know how and the tools already.
    ssanchez7610 -
  17. Nintendo 3DSの音量スイッチの交換: 手順 17、 2の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 17、 2の画像 2
    • スパッジャーの平面側先端や指の爪を使って、カメラリボンケーブルのZIFソケット上の固定フラップを跳ね上げます。
    • 再度組み立てる際は、ゴールドの接点がマザーボード側に面しているか確認してください(カメラケーブルのゴールドの接点と反対側を向いています)。
    Be sure to fit the motherboard inbetween the joystick and volume slider in properly (you can double check by seeing if the volume slider on the outside goes up and down smoothly). When I closed it the first time it was stuck on full volume so I needed to go back in and readjust!
    Veronika Todd - 返信
    When putting the cable back I recommend to open the 3ds while keeping it face down so the cable has more room to fit.
    Roberto Cantu - 返信
    Thank you so much, opening the 3ds is needed to fit the cable back easily.
    Halefall -
    The camera ribbon cable contacts face towards the motherboard, the speaker ones face away.
    David Madrigal - 返信
  18. Nintendo 3DSの音量スイッチの交換: 手順 18、 3の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 18、 3の画像 2 Nintendo 3DSの音量スイッチの交換: 手順 18、 3の画像 3
    • マザーボードを上部ケースに固定している次の7本のプラスネジを外します。
    • 2.5mmネジ(ゴールド) 4本
    • 3.5mmネジ(黒) 2本
    • 2.5mmネジ(シルバー) 1本
    • このネジを外すと、ボリュームスライダーが落ちることがあります。
    • 3DSの底部端にあるマザーボードの片側を持ち上げます。
    Do yourself a favor and DON'T remove the 2.5 mm silver screw (yellow circle). It just holds in a little plastic bit under the volume control. The board comes out just fine with the screw still in. If you remove it, the plastic bit will fall out at random when you turn over the case.
    First time I took mine apart, I noticed something fall out later, tracked it down and then puzzled over what it was and where it came from.
    Chupi - 返信
    There is some adhesive where the AC adapter plugs in so I recommend watching out for that
    Devin Stephenson - 返信
  19. Nintendo 3DSの音量スイッチの交換: 手順 19、 3の画像 1 Nintendo 3DSの音量スイッチの交換: 手順 19、 3の画像 2 Nintendo 3DSの音量スイッチの交換: 手順 19、 3の画像 3
    • 続けて、マザーボードアセンブリを持ち上げ、回転させてデバイス本体の隣に置きます。
    • スパッジャーの平面側先端や指の爪を使って、LCDリボンケーブルのZIFソケット上の固定フラップを跳ね上げます。
    • ソケットではなく、蝶番で動く固定フラップのみを跳ね上げているか確認してください。ソケットやケーブルを破損すると、3DSのトップ画面が機能しなくなります。
    Reinserting this ribbon cable is quite difficult. I found opening the case so that it sits upright at a 90 degree angle helps. The first two times I tried reassembling the top display did not work. Turned out that I was not inserting the ribbon cable in enough. I used tweezers to push this in by gently grabbing the ribbon cable. I was continually inspecting the cable for damage but apparently did not damage it. If anyone has a better idea on how to reinsert this cable I think others would greatly appreciate it.
    pbrazis - 返信
    Putting the cable back in is the hardest part out of all of this (if you can get past the screws near the beginning). If you have a friend that you trust very much and is very gentle, another pair of hands here really will help. If you're without a friend, make sure to use some flat, angled precision tweezers to push the ribbon in with one hand (pointed tweezers will do in a pinch but you'll have to be careful - I put a small dent in the ribbon and thought I'd broke it), and then use a spudge or something in the other to push the flap down.
    Also worth noting is that the ribbon for the top screen also handles the 3D - if you complete the guide and find you are unable to turn the 3D effect off, you didn't insert the ribbon enough, as I had the problem and re-inserting the ribbon fully fixed it.
    malcolmdemaggio - 返信
    Careful when reassembling -- watch the position of the black wifi antenna wire! I got mine most of the way back together and noticed it wouldn't close all the way. This wire had come out of the little posts holding it in place and was wedged between the screen and motherboard. Now I have to take it all apart again to fix this.
    Also if you're taking the board out of a working unit to get at the CLK signal to backup the NAND chip ("hardmod"), you don't need to remove the difficult ribbon cable in this step, or the other two wide ones at the top right from earlier. Leave them attached and swing the board out. It won't rotate a full 180 degrees to sit flat outside the unit, but you can open the screen 90 degrees to prop the rest up while having the board out on your table.
    Chupi - 返信
    I recommend not taking it off in the first place, as reattaching it is awfully difficult. You can easily clean out your abxy buttons with it still attached
    Martin - 返信
    I am having problems re-inserting the three ribbon cables (3DS XL). Do you need to flip up the retaining flaps first? (I just pulled them out of the slots when removing them.
    darren.brundell - 返信
    if the flap for the ribbon cable breaks what do you do
    lionmine ____ - 返信
    who else felt really proud after finally reinserting the cable
    Harrison Rigg - 返信
    The easiest way to get that ribbon back in is to hold it with some reverse tweezers that I fix it sells and use it to grab the ribbon and hold it while you fiddle with getting the ribbon in the slot. It’s super easy this way. You’ll have it installed in 36 seconds. Try it. (Reverse tweezers…press to release ones)
    Chris - 返信
  20. Nintendo 3DSの音量スイッチの交換: 手順 20、 1の画像 1
    • デバイス本体からマザーボードアセンブリを取り外します。
    Make sure when putting the motherboard back onto the bottom part of the casing that the antenna wire is where it should be - the first time I put this back together the wire got loose and was smooshed in between the casing and the Y and Power buttons, causing them to be stiff/not work. Using the spudge should help in pushing the wire back into the slots along the inside of the case.
    when reassembling, watch out for the wireless on/off slider - i had started screwing things back in when i realized the slider had slipped to the wrong side, making the slider non functional. by the same token, watch out for the volume slider on the other side.
    meatshaped - 返信
  21. Nintendo 3DSの音量スイッチの交換, 音量スイッチ: 手順 21、 2の画像 1 Nintendo 3DSの音量スイッチの交換, 音量スイッチ: 手順 21、 2の画像 2
    • スパッジャーの平面側先端を使って、マザーボード上のソケットから音量スイッチコネクタを持ち上げて外します。
  22. Nintendo 3DSの音量スイッチの交換: 手順 22、 1の画像 1
    • マザーボードから音量スイッチを取り外します。
終わりに
デバイスを再度組み立てるには、この説明書の逆の順番で組み立ててください。
3 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
railgunさんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
David Hodson
メンバー登録日: 04/13/10
150,500 ポイント
127のガイドは作成済み
2 件のコメント
What are all the tools I'd need to complete this repair? And where can I buy them?
Saiph Ichkuro - 返信
“Follow this guide in reverse” - I’m sorry, but that’s not helpful at all, the volume switch is near-impossible to put back in once fully removed from the motherboard!
Lucy - 返信
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 47
過去 30 日: 233
今までの合計 19,438
