メインコンテンツにスキップ
はじめに
This guide illustrates how to remove the upper rear panel from the Nintendo 2DS to access the battery and other parts of the device.
パーツ
  1. Remove the two Phillips screws securing the upper rear panel.
    • Remove the two Phillips screws securing the upper rear panel.
    • The screws will not completely detach from the back panel.
  2. Hinge the upper rear panel upwards and outwards to remove it. Hinge the upper rear panel upwards and outwards to remove it.
    • Hinge the upper rear panel upwards and outwards to remove it.
  3. Remove the battery from its housing by lifting it up from the side closest to the outside edge. Remove the battery from its housing by lifting it up from the side closest to the outside edge. Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
終わりに
27 の人々がこのガイドを完成させました。
Fina Beauchamp
メンバー登録日: 2015年01月12日
2,708 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015人のメンバー
CPSU-FORTE-W15S70G1
4 メンバー
31のガイドは作成済み
4 件のコメント
The only thing I was trying to figure out is if the bezel came up with the panel, and it’s not clear from these photos. For the record, it does not.
francis deible - 返信
This didnt help my problem
Artemy Matveev - 返信
I don’t know but my 2ds won’t turn on i repetivly press the power button but i charge it and try again but it won’t work help me plz
MATTHEW WINGATE - 返信
maybe its because you did not plug the battery correctly matthew
Ludovic Chartrain - 返信
コメントを追加
統計データを表示:
過去 24時間: 13
過去 7 日: 93
過去 30 日: 474
今までの合計 25,839
