はじめに
Nintendo 2DS のマザーボードは内部回路が搭載されており、解体作業は最大限の注意を払って行いましょう。ネジ頭を潰すなど、修理が不可能になるダメージは避けましょう。
必要な工具と部品
リアパネルに留められたプラスネジを10本外します。
Can't take off the screw top left next to the battery. What type of screwdriver do I use and where can I find some?
Little Mac - 返信
I used a husky with changeable heads, you could probably find one on amazon
接続しているリボンケーブルの位置を見つけるために、バックパネルを慎重に裏返します。
リアパネルとリボンケーブルを繋いでいるプラスネジを2本外します。
You can also detach the cable from the motherboard safely by flipping up the connector on the motherboard. Just don't forget to reattach. Some will find this tedious but may save time if you know what you're doing with said connectors.
Blackbeard - 返信
I agree, this is what the guide i followed said to do and since I was disconnecting all the other ribbon cables it made perfect sense to do it that way.
Lin -
pay attention: my 2ds dropped it's lens covers at this step
Likewise, I used a tiny drop of glue to put the lens back in place. Take care not to dirty the lens.
The picture you have there has the camera lens ribbon installed upside down. The ribbon needs to be pointing down when you re-attach it not up.
Agreed, ribbon cable looks upside down in picture
デバイスのケースのサイドパネルを手で摘んで、外側に引っ張りながら外します。
この3ヶ所にはリボンケーブルが接続されています。画像ではすでに外れていますが、このデバイスの分解を進める前に接続を外して下さい。
When reattaching during reassembly, take great care to ensure volume slider piece is correctly aligned with potentiometer tab on motherboard, otherwise volume control cannot be changed.
The are two small metal pins in the bottom corners of the case, take care not to misplace them.
The (3?) small ribbon cables on the bottom of the motherboard appear to already have been unplugged in this step. unplug them while unplugging the two large screen ribbon cables in step 10
What are the three ribbon cable at the bottom are supposed to be. Pls
メインボードを固定している真鍮色のプラスネジを12本外します。
I dont know if its just me but my gold mother board screws i had a few that just didnt fit right with a ph000. Maybe my screw driver is just garbage?
上部レール上に2本のネジがついています。このネジを外すと、ボタンと上部レールを外すことができます。
Joystickベースを固定している2本のネジがあります。このネジを外してください。(接続されたままのリボンケーブルにご注意ください)
指で上部パネルを摘んで、デバイスから引き抜いて外します。
When reassembling, take care to ensure all buttons, and rubber button pads are located correctly BEFORE securing the motherboard.
2本のリボンケーブルを固定している黒いフリップコネクタを持ち上げて、ケーブルの接続を外します。
正面側にある長方形のボードを持ち上げて、Joystickモーターである白いスクウェアを持ち上げて外します。どちらもマザーボードに装着しています。
あるモデルによって、スクリーンの下側にある3つの小さなリボンケーブルを取り出す必要があります。フリップアップタイプのコネクタで固定されています。作業は慎重に行なってください!
両側のマザーボードを摘んでから持ち上げて、取り出します。
Don't forget to disconnect the two tiny ribbon cables on the bottom of the motherboard that attach to the microphone and home button.
What happens if I can't get the ribbons to reattach? Is the board broke irreparably?
What about the top 2 wires
Briana the 3 wires on bottom of board are covered under screen 2 step 10.
y e e t y e e t m y d u d e s ! ! ! ! ! ! ! ! ! !!n ! ! ! ! ! ! ! ! ! !
The motherboard of my 2017(I think) 2DS is definitely laid out differently than in this guide, be careful.
Cosa succede se i connettori dei 3 piccoli cavi piatti si dovessero rompere??
How do I flip up the two ribbons ( need help desperately)
デバイスを再組立する際は、これらのインストラクションを逆の順番に従って作業を進めてください。
32 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
これらの翻訳者の方々は世界を修理する私たちのサポートをしてくれています。 あなたも貢献してみませんか?
翻訳を始める ›
13 件のコメント
o meu 2ds esta com um defeito que, quando eu aperto o botão de power ele liga e apos alguns segundo desliga e faz um pequeno barulho.
Would a jis #000 screw driver work better? As i tried a ph +000 and the gold motherboard screws just dont fit right
I have a question. After I replaced the mother board I have been having issues with it freezing after a couple mins running. Do you know why
I have a similar problem. After I replaced mine it will not open any app, and it does not show the status bar. Does anyone know why?
Now that I've removed the motherboard, how do I fix it? The instructible is great as far as it goes, but it doesn't go far enough
Fix what? You need to be more specific. I have to purchase a screen from China in order to fix mine.
I have a quarter inch metal pin left over. Don’t see it in any tutorials. Anyone know where it’s from?
I have the same thing, It came out when I was removing the back panel. I believe it was located towards the bottom of the panel. I’m scouring forums to see where it goes. Found this on Youtube! https://www.youtube.com/watch?v=qjoPIt5K... looks like it is just a reinforcement pin for a lanyard in the bottom corners.
Kwag -
where do i buy a motherboaRD
Depends on the country where you live. In Europe, some countries have apps (flesh market) where you will find used motherboards of Nintendo. (Wallapop, Vinted...)
For the rest of the world, you can try a l i e x p r e s s . c o m or similar.
