はじめに
If your blender is too loud, your fan may be damaged or loose. This guide will show you how to replace a broken or damaged fan.
必要な工具と部品
Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
Lift the base up to remove it.
もう少しです!
終わりに
コメント 1 件
I did that but the other fan is the one that is lock and do not turn on. The white one in the middle. How can I fix it.
