はじめに
The Ninja NJ600 blender has an LED light display to help the user operate it. This guide will show how to replace one of these lights.
必要な工具と部品
Remove the five screws (13mm long, 6mm head diameter) using a Phillips #2 screwdriver.
Remove these four screws (10mm long, 5mm head diameter) using a Phillips #2 screwdriver.
Locate the LED you wish to desolder.
On the bottom of the board, each LED is designated with a small triangle with a line at one tip.
もう少しです!
終わりに
