はじめに
In the event that your device overheats, the cooling fan may need to be replaced. This guide will show you step-by-step how to do so.
必要な工具と部品
Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
Using caution, hold the fan steady and use a wrench or pliers to remove the nut securing the fan.
Loosen the washer with a flathead screwdriver, then remove the fan and replace with a new one.
ある他の人がこのガイドを完成しました。
