はじめに
This will work as a prerequisite guide for all other guides. This helps us break down the device into the main base layer.
必要な工具と部品
Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
終わりに
ある他の人がこのガイドを完成しました。
