メインコンテンツにスキップ
Ninja Coffee Bar CF086 Power Cord Replacement
必要な工具と部品
  1. Ninja Coffee Bar CF086 Power Cord Replacement, Water Heating Element: 手順 1、 2の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement, Water Heating Element: 手順 1、 2の画像 2
    • Make sure the Ninja Coffee Bar is unplugged and that you have a dry, clean workspace for this task.
    • Remove the carafe and water reservoir and set them aside.
  2. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 2、 1の画像 1
    • Unscrew the T-10 screws from the bottom cover of the machine, and remove that bottom cover.
  3. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 3、 1の画像 1
    • Unscrew and remove the heating plate layer. This will expose the internal workings of the machine.
  4. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 4、 1の画像 1
    • Locate the water heating element in the interior of your coffee maker.
    • Unscrew the two indicated J1S1 screws at the base of the water heating element.
  5. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 5、 1の画像 1
    • Unscrew and remove the remaining J1S1 screws that secure the water heating element to the interior of the device.
  6. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 6、 3の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 6、 3の画像 2 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 6、 3の画像 3
    • Grasp and remove the clamp securing the tube that feeds into the base of the water heating element.
    • Detach the tube from the water heating element.
  7. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 7、 2の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 7、 2の画像 2
    • Locate the coated wire that feeds into the side of the water heating element. Remove this wire.
  8. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 8、 2の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 8、 2の画像 2
    • Locate the two wires leading out from the water heating element that feed into crimp connectors.
    • Using side cutters, sever these wires near the crimp connectors.
    • Use the side cutters to cut the remaining wires that feed into the crimp connectors from the coffee machine.
  9. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 9、 2の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 9、 2の画像 2
    • Squeeze and remove the clamp that secures the main tube feeding into the water heating element. Remove that tube.
    • Remove the water heating element.
  10. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 10、 3の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 10、 3の画像 2 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 10、 3の画像 3
    • Using wire strippers, strip the cut wires from your coffee machine near their cut ends to expose 2 cm of metal conductor from each.
    • Use a similar procedure to strip the wires from your replacement heating element. Using wire strippers, expose 2 cm of metal conductor from the ends of the wires.
  11. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 11、 1の画像 1
    • Prepare two crimp connectors by filling them with dielectric grease.
    • Use a crimp connector to connect a stripped end of the wire leading from the replacement heating element to the stripped end of the corresponding wire from the coffee maker.
    • Using a second crimp connector, repeat for the remaining pair of stripped wires.
    • Using the appropriate crimping tool, crimp the connectors.
  12. Ninja Coffee Bar CF086 Power Cord Replacement, Power Cord: 手順 12、 2の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement, Power Cord: 手順 12、 2の画像 2
    • The power cord splits into two and feeds into two closed-end crimp connectors. Two wires from your coffee machine also enter these connectors.
    • Locate the neutral wire that feeds into the crimp connector from the machine. Mark this wire.
  13. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 13、 2の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 13、 2の画像 2
    • Using side cutters, cut the wires from your device below the crimp connectors.
  14. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 14、 3の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 14、 3の画像 2 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 14、 3の画像 3
    • Using wire strippers, carefully expose a 2 cm length of the metal wire from each of the cut ends.
  15. Ninja Coffee Bar CF086 Power Cord Replacement: 手順 15、 2の画像 1 Ninja Coffee Bar CF086 Power Cord Replacement: 手順 15、 2の画像 2
    • Apply dielectric grease to the insides of two new crimp connectors.
    • Insert the stripped ends of the wire into the crimp connectors.
    • Locate the ends of the replacement power cord. These should be already stripped; if they are not, strip 2 cm from them using wire strippers.
    • Feed the ends of the replacement power cord into the crimp connectors. Crimp the connectors using the appropriate crimping tool.
終わりに
After the wires have been spliced, the new power cord is ready for use with your machine.
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
David Ton
メンバー登録日: 10/02/17
630 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team S1-G5, Thompson Fall 2017 USF Tampa, Team S1-G5, Thompson Fall 2017人のメンバー
USFT-THOMPSON-F17S1G5
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 25
今までの合計 3,694
