メインコンテンツにスキップ
Ninja Coffee Bar CF080 Control Panel Replacement
必要な工具と部品
  1. Ninja Coffee Bar CF080 Control Panel Replacement, Heated Plate: 手順 1、 1の画像 1
    • Face the machine bottom towards you.
  2. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 2、 2の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 2、 2の画像 2
    • Unscrew six 0.6cm screws by holding the bottom board with Torx #10 screwdriver to remove the board.
    • Unscrew one 0.6 cm screw with PH1 screwdriver to remove the board.
  3. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 3、 3の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 3、 3の画像 2 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 3、 3の画像 3
    • With moderate force remove and place the "plastic opening tool" between the divide in order to remove the bottom board.
  4. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 4、 3の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 4、 3の画像 2 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 4、 3の画像 3
    • Remove the bottom board with moderate force.
  5. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 5、 1の画像 1
    • Unscrew eight 0.6cm sized screws with Phillips #1 screwdriver, holding the silver secures on the sides of the heated plate.
    • Four screws on each side, two silver secures to remove the securers, located on the sliver bar holding the heated plate (one on each end).
  6. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 6、 1の画像 1
    • Unscrew two 0.6cm sized screws Phillips #1 screwdriver.
    • The silver bar will fall off once screws are removed.
  7. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 7、 2の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 7、 2の画像 2
    • Remove the heated plate from the machine with easy glide.
  8. Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: 手順 8、 3の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: 手順 8、 3の画像 2 Ninja Coffee Bar CF080 Control Panel Replacement, Power Module: 手順 8、 3の画像 3
    • Remove the nine 0.5cm screws with Phillips #2 screwdriver.
    • Some screws are harder to see due to how deep the holes are.
    • Recommend using Extender 4 with Phillips #2 screwdriver to help unscrew the screws within the deep holes of the machine.
  9. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 9、 2の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 9、 2の画像 2
    • Remove the two 0.6cm with Phillips #2 screwdriver.
  10. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 10、 3の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 10、 3の画像 2 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 10、 3の画像 3
    • Detach various colored cords from one another, using both hands to place thumb and index finger to hold each grip then separate by pulling with the degree of force.
    • There with be 1 blue, 1 black, 1 red and 2 white.
  11. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 11、 2の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 11、 2の画像 2
    • Remove the black board by maneuvering it through the cords.
  12. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 12、 3の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 12、 3の画像 2 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 12、 3の画像 3
    • Grip the bottom end of the panel and pull it towards you to remove the module from the machine.
  13. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 13、 2の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 13、 2の画像 2
    • Remove the three 0.6cm screws with Phillips #1 screwdriver.
    • They are in the black holes, 1 at the top and two at the bottom.
  14. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 14、 1の画像 1
    • Remove the black board attached to the module.
  15. Ninja Coffee Bar CF080 Control Panel Replacement, Control Panel: 手順 15、 2の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement, Control Panel: 手順 15、 2の画像 2
    • Unscrew four 1.2cm screws with Phillips #2 screwdriver.
  16. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 16、 2の画像 1 Ninja Coffee Bar CF080 Control Panel Replacement: 手順 16、 2の画像 2
    • Carefully remove the control panel from the control module.
  17. Ninja Coffee Bar CF080 Control Panel Replacement: 手順 17、 1の画像 1
    • Left with the control module.
終わりに
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Jan Chen
メンバー登録日: 09/11/17
235 ポイント
2のガイドは作成済み
チーム
CSU Fullerton, Team S1-G1, Bruce Fall 2017 CSU Fullerton, Team S1-G1, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S1G1
4 メンバー
5のガイドは作成済み
コメント 1 件
This is great an all, but WHERE do you get the new control board?!? Without it this is worthless...
madmikey - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 20
今までの合計 1,877
