メインコンテンツにスキップ
Ninja Coffee Bar CF080 Brewer Head Replacement
必要な工具と部品
  1. Ninja Coffee Bar CF080 Brewer Head Replacement, Brewer Head: 手順 1、 1の画像 1
    • Face the coffee machine in front of you.
    • Make sure that the coffee machine is unplugged.
    • Remove the glass carafe as it will not be needed.
  2. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 2、 1の画像 1
    • Firmly grab the tab sticking out from the head of the brewer.
  3. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 3、 3の画像 1 Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 3、 3の画像 2 Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 3、 3の画像 3
    • With little force, pull the tab of the brewer head in reverse direction.
  4. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 4、 1の画像 1
    • Slide off the head in the direction away from the machine.
    • If the head does not come off smoothly by sliding, give a firm tug in the same direction.
  5. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 5、 3の画像 1 Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 5、 3の画像 2 Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 5、 3の画像 3
    • Hold the head in the same position and lift it forward until the Ninja is facing upward toward the ceiling.
  6. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 6、 1の画像 1
    • Now the brewer head is positioned to where you can seeing the bottom.
  7. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 7、 2の画像 1 Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 7、 2の画像 2
    • Remove the screw with a Phillips #1 screwdriver.
    • Use Phillips #1 screwdriver.
    • Along will come a small black screw cover and spring
  8. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 8、 1の画像 1
    • Twist the black lid on top clockwise until it is completely detached.
  9. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 9、 1の画像 1
    • With the black upper lid detached, a smaller black cover can be removed without effort.
  10. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 10、 2の画像 1 Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 10、 2の画像 2
    • Remove the 6 screws from the seal with a Phillips #1 screwdriver.
  11. Ninja Coffee Bar CF080 Brewer Head Replacement: 手順 11、 1の画像 1
    • Once all screws are detached from the brewer head, it will be separated into two pieces leaving the filter.
終わりに
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
Elizabeth Nguyen
メンバー登録日: 09/11/17
416 ポイント
3のガイドは作成済み
チーム
CSU Fullerton, Team S1-G1, Bruce Fall 2017 CSU Fullerton, Team S1-G1, Bruce Fall 2017人のメンバー
CSUF-BRUCE-F17S1G1
4 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 997
