メインコンテンツにスキップ
Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement
必要な工具と部品
  1. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement, Drip Stop Toggle and Brew Basket: 手順 1、 1の画像 1
    • Slide the brew baskets to the open position.
  2. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 手順 2、 1の画像 1
    • Remove three 6mm screws with Phillips head screw driver.
  3. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 手順 3、 3の画像 1 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 手順 3、 3の画像 2 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 手順 3、 3の画像 3
    この手順で使用する道具:
    購入する
    • Using needle nose tweezers, push the bottom of the pin up from behind the brew basket
    • Pull the pin out.
  4. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 手順 4、 1の画像 1
    • Remove brew basket from swinging basket holder
  5. Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 手順 5、 2の画像 1 Ninja Coffee Bar® Single-Serve System Drip Stop Toggle and Brew Basket Replacement: 手順 5、 2の画像 2
    • Use a Phillips screwdriver to remove one 6mm screw from the drip stop toggle.
    • Remove the drip stop toggle.
終わりに
作成者
4人の作成者と共同で作成されました。
Naser Aldousari
メンバー登録日: 10/10/17
310 ポイント
3のガイドは作成済み
チーム
USF Tampa, Team S13-G69, Cagle Fall 2017 USF Tampa, Team S13-G69, Cagle Fall 2017人のメンバー
USFT-CAGLE-F17S13G69
4 メンバー
3のガイドは作成済み
3 件のコメント
Can you provide more detail regarding the small spring that you provide the warning for? The one that needs to stay in place. If it does fall out, how can not be fixed or rather where does not go?
Dani - 返信
Agree! The spring NEEDS to be resting vertically in between the two clips, in my case, these have worn and the spring came out of seat. It needed to be refastened and the five beeps, “of death” have disappeared and my coffeepot functions again!
Marcus Martinez - 返信
* this works on the ninja coffee bar larger system as well
Marcus Martinez -
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 44
今までの合計 6,968
