メインコンテンツにスキップ
Ninja AF161 Max XL Gray Frame Replacement
必要な工具と部品
  1. Ninja AF161 Max XL Gray Frame Replacement, Back Vent Cover: 手順 1、 1の画像 1
    • The back vent cover is directly above where the power cord protrudes.
  2. Ninja AF161 Max XL Gray Frame Replacement: 手順 2、 2の画像 1 Ninja AF161 Max XL Gray Frame Replacement: 手順 2、 2の画像 2
    • Use a Phillips #2 screwdriver to unscrew and remove four 1 cm screws from the panel.
  3. Ninja AF161 Max XL Gray Frame Replacement: 手順 3、 2の画像 1 Ninja AF161 Max XL Gray Frame Replacement: 手順 3、 2の画像 2
    • Once unscrewed, remove all four screws in order to remove the back vent cover.
  4. Ninja AF161 Max XL Gray Frame Replacement, Gray Frame: 手順 4、 2の画像 1 Ninja AF161 Max XL Gray Frame Replacement, Gray Frame: 手順 4、 2の画像 2
    • After you have the vent removed, you will see two 2.2 cm screws holding the casing in. Use a Phillips #1 screwdriver to remove the two screws.
    • Be wary that the two screws are quite tight and will require a bit of torsion to get out.
  5. Ninja AF161 Max XL Gray Frame Replacement: 手順 5、 3の画像 1 Ninja AF161 Max XL Gray Frame Replacement: 手順 5、 3の画像 2 Ninja AF161 Max XL Gray Frame Replacement: 手順 5、 3の画像 3
    • Use the a plastic opening tool or a similar object to wedge between the silver top and black rim.
    • Pry all four sides towards the middle with a plastic opening tool to release the tabs.
    • The tabs on the top will make sounds while being detached from the device.
  6. Ninja AF161 Max XL Gray Frame Replacement: 手順 6、 2の画像 1 Ninja AF161 Max XL Gray Frame Replacement: 手順 6、 2の画像 2
    • Unscrew the four 2.2 cm screws with a Phillips #1 screwdriver.
  7. Ninja AF161 Max XL Gray Frame Replacement: 手順 7、 2の画像 1 Ninja AF161 Max XL Gray Frame Replacement: 手順 7、 2の画像 2
    • Lay the air fryer on its side.
  8. Ninja AF161 Max XL Gray Frame Replacement: 手順 8、 2の画像 1 Ninja AF161 Max XL Gray Frame Replacement: 手順 8、 2の画像 2
    • Remove six 1.4 cm screws with the TR15 Torx Security Screwdriver.
  9. Ninja AF161 Max XL Gray Frame Replacement: 手順 9、 1の画像 1
    • Keep the device on its side, and unscrew and remove two 1.4 cm screws with a Phillips #1 screwdriver.
  10. Ninja AF161 Max XL Gray Frame Replacement: 手順 10、 1の画像 1
    • The lid can now be lifted off. Remove by prying the bottom apart and lifting.
    • After lifting the lid, you will see the white and yellow wire heads that connect the air fryer display screen to the motherboard.
  11. Ninja AF161 Max XL Gray Frame Replacement: 手順 11、 3の画像 1 Ninja AF161 Max XL Gray Frame Replacement: 手順 11、 3の画像 2 Ninja AF161 Max XL Gray Frame Replacement: 手順 11、 3の画像 3
    • Pinch the white tab and wire head together and pull to release the connector.
    • Take care to not bend the circuit board while attempting removal of this connector. This will damage the circuit board.
終わりに
作成者
3人の作成者と共同で作成されました。
Alina Sanchez
メンバー登録日: 02/14/23
303 ポイント
2のガイドは作成済み
チーム
Utah Tech University, Team 1-5, McMurrin Spring 2023 Utah Tech University, Team 1-5, McMurrin Spring 2023人のメンバー
UTAHTECH-MCMURRIN-S23S1G5
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 13
今までの合計 243
