はじめに
The fan inside the Ninja AF161 Max XL helps circulate warm air to cook food. Should you need to replace this fan, this guide walks you through those steps. This is a more difficult process, but this guide will help you find success.
必要な工具と部品
After you have the vent removed, you will see two 2.2 cm screws holding the casing in. Use a Phillips #1 screwdriver to remove the two screws.
Remove the two 4.7 cm screws and washers using a Phillips #1 screwdriver, and then remove the silver piece on top of the motor.
Simply lift the motor up and gently place it to the side.
