はじめに
The communication board sends information about the aperture and focus of the lens. If you are having trouble with focus or aperture, then there may be a problem with the communication board.
必要な工具と部品
Remove the three loose parts (spring, small rod, and metal ring) that were under the lens mount and put them aside.
5 の人々がこのガイドを完成させました。
3 件のコメント
Doesn't work for the 301, although it looks similar I can't find any way to remove the top or the front case
The F301 and N2000 are identical, so the guide should work. In this guide the top case isn't removed, as the film rewind knob is preventing it from coming off completely, and instead just lifted with the bit of leeway the popped up rewind knob provides.
