はじめに
If you are having trouble mounting the lens and you are sure you have the correct lens type (see the camera manual for types of lenses that can be used), then use this guide to assist with replacing the lens mount.
パーツ
パーツは必要ありません。
  1. Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
    • Use a 00 Phillips head screwdriver to remove the four screws from the lens mount.
  2. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  3. Remove lens mount from the camera.
    • Remove lens mount from the camera.
    • Be careful not to lose any of the three loose pieces that are under the lens mount.
まとめ
4 の人々がこのガイドを完成させました。
Zachary Phillips
メンバー登録日: 2011年04月08日
205 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S25G26
3 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 21
今までの合計 4,595
