はじめに
Back case acts as a door to access change out film. It can be easily removed from the device and replaced if it becomes cracked or otherwise unusable.
    • In this guide we will refer to 'left' and 'right' as though the camera is facing away from you.
    • Pull up on the film rewind lever on the top left of the camera to release the back door.
    • Once the door is released, open it completely.
  1. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
    • Locate the silver tab on the inside of the door hinge. Slide this down to free the hinge and remove it from the camera.
まとめ
Zachary Phillips
メンバー登録日: 2011年04月08日
205 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 25-26, Garner Spring 2011 Cal Poly, Team 25-26, Garner Spring 2011人のメンバー
CPSU-GARNER-S11S25G26
3 メンバー
7のガイドは作成済み
統計データを表示:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 8
今までの合計 2,192
