メインコンテンツにスキップ
Nikon D90 Rear Display Buttons Replacement
必要な工具と部品
  1. Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: 手順 1、 2の画像 1 Nikon D90 Rear Display Buttons Replacement, Removing Casing Screws: 手順 1、 2の画像 2
    • Locate the screws on both sides of the camera.
    • Remove the four 6.3 mm Phillips screws using a PH00 screwdriver.
    • Be careful not to strip the screws.
  2. Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: 手順 2、 3の画像 1 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: 手順 2、 3の画像 2 Nikon D90 Rear Display Buttons Replacement, Removing the Rear Casing: 手順 2、 3の画像 3
    • Use a plastic opening tool to separate the rear case from the camera.
  3. Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: 手順 3、 2の画像 1 Nikon D90 Rear Display Buttons Replacement, Disconnecting the Ribbon Cables: 手順 3、 2の画像 2
    • After, remove the two orange ribbon connectors attached to the interior of the camera with tweezers.
    • Make sure to remove the ribbon cables carefully from the connectors to avoid damaging the camera.
  4. Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: 手順 4、 2の画像 1 Nikon D90 Rear Display Buttons Replacement, Removing the Screws from the Rear Casing: 手順 4、 2の画像 2
    • Remove the screws from the back assembly with a Phillips (PH00) head screwdriver.
    • Remove the ten 5.3 mm Phillips screws.
    • Remove the three 4.3 mm Phillips screws.
  5. Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: 手順 5、 3の画像 1 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: 手順 5、 3の画像 2 Nikon D90 Rear Display Buttons Replacement, Removing the LCD and other components: 手順 5、 3の画像 3
    • Use a plastic opening tool to separate the LCD and metal plates from the casing.
  6. Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: 手順 6、 3の画像 1 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: 手順 6、 3の画像 2 Nikon D90 Rear Display Buttons Replacement, Removing the Display Buttons: 手順 6、 3の画像 3
    • Use a plastic opening tool to separate the buttons from the casing.
    • Remove the 4.3 mm Phillips screw from the knob using a PH00 screwdriver.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
jonothon cawley
メンバー登録日: 10/20/14
354 ポイント
2のガイドは作成済み
チーム
UMass Dartmouth, Team 1-7, Duarte Fall 2014 UMass Dartmouth, Team 1-7, Duarte Fall 2014人のメンバー
UMASSD-DUARTE-F14S1G7
3 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 2,562
