メインコンテンツにスキップ
Nikon D7100 Headphone/Microphone Replacement
必要な工具と部品
  1. Nikon D7100 Headphone/Microphone Replacement, LCD Screen: 手順 1、 1の画像 1
    • When loosening the screws, start pressing the screwdriver firmly for the first 1-2 turns (highest torque) until the screw is 'unlocked'. Failing to do so can damage the screw head and make it impossible to disengage that screw.
    • Remove the five screws on the bottom of the camera with a JIS #000 head screwdriver.
  2. Nikon D7100 Headphone/Microphone Replacement: 手順 2、 1の画像 1
    • Remove the 3 screws under the battery flap and remove the bottom cover.
  3. Nikon D7100 Headphone/Microphone Replacement: 手順 3、 1の画像 1
    • Remove the 2 screws inside the camera on the back corners.
  4. Nikon D7100 Headphone/Microphone Replacement: 手順 4、 1の画像 1
    • Open the HDMI flap and remove the 2 screws.
  5. Nikon D7100 Headphone/Microphone Replacement: 手順 5、 1の画像 1
    • Remove the screw next to the camera strap loop.
  6. Nikon D7100 Headphone/Microphone Replacement: 手順 6、 1の画像 1
    • Remove the 2 screws on each side of the view finder.
  7. Nikon D7100 Headphone/Microphone Replacement: 手順 7、 1の画像 1
    • Remove the 2 screws above and below the SD card flap.
  8. Nikon D7100 Headphone/Microphone Replacement: 手順 8、 1の画像 1
    • Peel off the adhesive leather screw cover and remove the 2 screws under it.
  9. Nikon D7100 Headphone/Microphone Replacement: 手順 9、 2の画像 1 Nikon D7100 Headphone/Microphone Replacement: 手順 9、 2の画像 2
    • Remove the Diopter adjustment control sticker and remove the screw under it.
  10. Nikon D7100 Headphone/Microphone Replacement: 手順 10、 1の画像 1
    • Separate the back panel of the camera from the actual camera.
    • Be careful not to tear any of the ribbon cables.
  11. Nikon D7100 Headphone/Microphone Replacement: 手順 11、 1の画像 1
    • Disconnect the LCD ribbon cables and power cable from the motherboard.
  12. Nikon D7100 Headphone/Microphone Replacement: 手順 12、 2の画像 1 Nikon D7100 Headphone/Microphone Replacement: 手順 12、 2の画像 2
    • Unscrew all 16 screws around the back plate of the camera.
  13. Nikon D7100 Headphone/Microphone Replacement: 手順 13、 1の画像 1
    • Then unscrew the remaining screws holding the back plate to the LCD.
    • Then simply remove the plate with the LCD.
  14. Nikon D7100 Headphone/Microphone Replacement, Motherboard: 手順 14、 1の画像 1
    • Undo the 5 ribbon cable connectors by flipping the latches up with a plastic spudger.
  15. Nikon D7100 Headphone/Microphone Replacement: 手順 15、 1の画像 1
    • Remove the black 4 pin connector by pulling it out of the connector.
  16. Nikon D7100 Headphone/Microphone Replacement: 手順 16、 1の画像 1
    • Remove the 7 screws holding the motherboard in place.
  17. Nikon D7100 Headphone/Microphone Replacement: 手順 17、 1の画像 1
    • This is what you should see after removing the motherboard.
  18. Nikon D7100 Headphone/Microphone Replacement, Headphone and Microphone Module: 手順 18、 1の画像 1
    • After following the guide to remove the back LCD screen from the motherboard, remove the 2 marked screws.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Wesley Eveld
メンバー登録日: 02/20/18
732 ポイント
4のガイドは作成済み
チーム
USF Tampa, Team S11-G6, Cheng Spring 2018 USF Tampa, Team S11-G6, Cheng Spring 2018人のメンバー
USFT-CHENG-S18S11G6
4 メンバー
6のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 11
今までの合計 1,070
