このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Then next step is removing the seven Philips #00 screws that hold the rear face plate on.
There are screws hidden in three separate spots.
One is under the rubber doors on the left side of the camera. the next one at the eye hole.
The final one involves taking off the small dial that is about half an inch to the right of the eye hole.
Removing this dial involves putting a spungder tool behind it and applying a gradual amount of pressure.
この手順は未翻訳です。 翻訳を手伝う。
It is now possible to remove the last three Philips #00 screws that are hidden under the memory card slot door.
The screws come out and the cover comes straight off.
The last cover plate is the top. The top is held on by two screws located just beneath the rim of the cover.
この手順は未翻訳です。 翻訳を手伝う。
The rear side of the camera is where the motherboard is located. It is visible after you have taken off the rear face plate.
Remove the shield that protects it from static first.
This shield has six Philips #00 screws that are positioned around the edge of the shield.
After removal of the screws the shield will come free from the motherboard.
2 の人々がこのガイドを完成させました。
