メインコンテンツにスキップ
Nikon D5100 Rear Panel Replacement
必要な工具と部品
  1. Nikon D5100 Rear Panel Replacement, Rear Panel: 手順 1、 2の画像 1 Nikon D5100 Rear Panel Replacement, Rear Panel: 手順 1、 2の画像 2
    • Remove the five screws around the camera using a Phillips #00 screwdriver.
    • Remember that we're removing the rear panel, so for this step, only remove screws on the appropriate side of the seam separating the rear and front panels.
    • The D5100 is held together by a large number of screws, which come in several sizes. Make sure to keep your screws organized so that you don't lose or misplace them!
  2. Nikon D5100 Rear Panel Replacement: 手順 2、 1の画像 1
    • Use your fingernail to gently peel back the black rubber thumb grip, attached to the chassis with a strong adhesive.
    • Use the Phillips #00 to remove the screw underneath the black rubber grip.
  3. Nikon D5100 Rear Panel Replacement: 手順 3、 2の画像 1 Nikon D5100 Rear Panel Replacement: 手順 3、 2の画像 2
    • Carefully peel back the black rubber hand grip, which is attached to the chassis with a strong adhesive.
    • Use the Phillips #00 to remove two screws beneath the handgrip.
  4. Nikon D5100 Rear Panel Replacement: 手順 4、 2の画像 1 Nikon D5100 Rear Panel Replacement: 手順 4、 2の画像 2
    • Using a spudger, pry off the diopter adjustment dial cover and remove the screw underneath.
    • Be sure to remove the very thin cover from the dial, and not the dial itself.
    • The dial cover is not shown in this picture.
    • Next, using a Phillips #00 screwdriver, remove the three Phillips screws around the viewfinder.
  5. Nikon D5100 Rear Panel Replacement: 手順 5、 1の画像 1
    • Carefully separate the rear panel from the camera body.
    • You will notice some resistance because the two pieces of the camera fit together tightly.
    • Be careful not to damage the chassis or ribbon cables. Use a firm grip to pull the two halves apart.
  6. Nikon D5100 Rear Panel Replacement: 手順 6、 2の画像 1 Nikon D5100 Rear Panel Replacement: 手順 6、 2の画像 2
    • Remove the dark orange ribbon cable attaching the rear panel to the motherboard by flipping the black plastic clasp up, away from the motherboard, and pull the cable out of its white casing in the direction of the cable.
    • Using the flat edge of a spudger can help with this delicate task.
  7. Nikon D5100 Rear Panel Replacement: 手順 7、 2の画像 1 Nikon D5100 Rear Panel Replacement: 手順 7、 2の画像 2
    • Remove the silver 16-pin cable by pulling gently upwards, away from the inside of the camera, until it separates from its port.
    • At this point, the rear panel is fully separated from the main body of the camera.
終わりに
7 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Liz
メンバー登録日: 04/25/14
1,311 ポイント
5のガイドは作成済み
チーム
Cal Poly, Team 10-54, Amido Spring 2014 Cal Poly, Team 10-54, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S10G54
4 メンバー
5のガイドは作成済み
コメント 1 件
Any ideas of why the screen looks yellowish with a green stripe? :(
kuin_v - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 24
今までの合計 5,225
