メインコンテンツにスキップ
Nikon D500 Memory Card Cover Disassembly
必要な工具と部品
    • Remove the Memory Card(s) from the camera
    • Remove the Battery from the Camera, and close the battery compartment cover
  1. Nikon D500 Memory Card Cover Disassembly, Remove 2 exposed screws: 手順 2、 1の画像 1
    • Remove the 2 screws beside the memory slots, then close the cover.
    • Note: make sure to remove the memory cards first!
  2. Nikon D500 Memory Card Cover Disassembly, Remove 2 screws under grip: 手順 3、 1の画像 1
    • Remove the 2 screws under the rubber grip part by peeling back the rubber grip
    • Try not to damage the double sided adhesive under the rubber.
  3. Nikon D500 Memory Card Cover Disassembly, Remove 2 screws under rear grip: 手順 4、 1の画像 1
    • Remove the 2 screws under the rubber pad marked in red.
    • Try not to damage the double-sided adhesive under the rubber.
    • Note: There is a 3rd screw under the flap, which holds the back to the top (marked in yellow). If needing to remove the back panel not just the memory cover flap, it can be removed at this time as well.
    • Lift out the assembly panel, it should come free without much force.
    • May open the panel to release it.
終わりに
作成者
1人の作成者と共同作成されました。
Wolphin
メンバー登録日: 11/11/19
1,725 ポイント
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 29
今までの合計 884
