はじめに
This is the steps of removal of the rear panel from the camera, exposing the main board.
必要な工具と部品
Remove the Memory Card(s) from the camera
Remove the Battery from the Camera, and close the battery compartment cover
Remove the 2 screws beside the memory slots, then close the cover.
Note: make sure to remove the memory cards first!
Remove the 2 screws under the rubber grip part by peeling back the rubber grip
Try not to damage the double sided adhesive under the rubber.
Remove the 2 screws under the rubber pad marked in red.
Try not to damage the double-sided adhesive under the rubber.
Note: There is a 3rd screw under the flap, which holds the back to the top (marked in yellow). If needing to remove the back panel not just the memory cover flap, it can be removed at this time as well.
Lift out the assembly panel, it should come free without much force.
May open the panel to release it.
Remove the 4 screws holding the plate to the bottom.
Remove the bottom plate
Remove the 4 screws (1 was under the plate removed under the last step)
Remove the screw under the grip, if it has not been removed doing a previous step
Carefully pull the back plate off the camera
There are 2 ribbon cables that need to be disconnected from the main board to free the rear panel from the camera.
To release the cables by flipping up the tap on the side away from the cable
When reconnecting the cables, make sure the cables are fully seated before flipping the latch back down.
The black cable goes to the LCD (on the tilt screen), the other one goes to the buttons.
The LCD cable does have less slack, so is easier to release first, and reconnect last.
ある他の人がこのガイドを完成しました。
