メインコンテンツにスキップ
Nikon Coolpix S9700 Back Panel Replacement
必要な工具と部品
  1. Nikon Coolpix S9700 Back Panel Replacement, Battery: 手順 1、 2の画像 1 Nikon Coolpix S9700 Back Panel Replacement, Battery: 手順 1、 2の画像 2
    • Press the ON/OFF button to power off the S9700.
    • Not doing so can damage the S9700 or cause electric shock.
  2. Nikon Coolpix S9700 Back Panel Replacement: 手順 2、 3の画像 1 Nikon Coolpix S9700 Back Panel Replacement: 手順 2、 3の画像 2 Nikon Coolpix S9700 Back Panel Replacement: 手順 2、 3の画像 3
    • Place the S9700 upside down
    • Place your finger on the battery compartment cover and gently push toward the front of the S9700.
    • The cover will open up by itself.
  3. Nikon Coolpix S9700 Back Panel Replacement: 手順 3、 3の画像 1 Nikon Coolpix S9700 Back Panel Replacement: 手順 3、 3の画像 2 Nikon Coolpix S9700 Back Panel Replacement: 手順 3、 3の画像 3
    • Push the yellow tab inside the battery compartment in the direction of the arrow. This will allow the battery to spring up.
  4. Nikon Coolpix S9700 Back Panel Replacement: 手順 4、 2の画像 1 Nikon Coolpix S9700 Back Panel Replacement: 手順 4、 2の画像 2
    • Grab the battery and pull out.
  5. Nikon Coolpix S9700 Back Panel Replacement, Back Panel: 手順 5、 2の画像 1 Nikon Coolpix S9700 Back Panel Replacement, Back Panel: 手順 5、 2の画像 2
    • Remove the two 4-mm and three 3-mm J000 screws from the bottom of the S9700.
    • Three 3-mm screws are on the side opposite the battery compartment.
    • Two 4-mm screws are on the side with the battery compartment. One of these screws is in the battery compartment. Open it up for access.
  6. Nikon Coolpix S9700 Back Panel Replacement: 手順 6、 2の画像 1 Nikon Coolpix S9700 Back Panel Replacement: 手順 6、 2の画像 2
    • Remove the one 3-mm J000 screw on the left side of the S9700 (side with no ports).
    • Remove the two 3-mm J000 screws on the right side (side with HDMI and charging ports).
    • One of these screws is underneath the HDMI port cover. Lift the port cover up to access.
  7. Nikon Coolpix S9700 Back Panel Replacement: 手順 7、 3の画像 1 Nikon Coolpix S9700 Back Panel Replacement: 手順 7、 3の画像 2 Nikon Coolpix S9700 Back Panel Replacement: 手順 7、 3の画像 3
    • Insert the plastic opening tool on the bottom of the S9700 between the front panel and the back panel.
    • Twist the plastic opening tool so that both halves separate.
    • When both halves are separated, the HDMI cover, charging cover, and the ON/OFF switch will fall out.
    • There is a flex ribbon attached to the back panel. Forcing the back panel off may rip it.
  8. Nikon Coolpix S9700 Back Panel Replacement: 手順 8、 3の画像 1 Nikon Coolpix S9700 Back Panel Replacement: 手順 8、 3の画像 2 Nikon Coolpix S9700 Back Panel Replacement: 手順 8、 3の画像 3
    • Remove the three silver 3-mm J000 screws on the back panel holding the silver button / dial component to the panel and ribbon.
    • Gently remove the back panel.
終わりに
作成者
3人の作成者と共同で作成されました。
Matt Staubus
メンバー登録日: 10/05/16
849 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 9-5, Lacy Fall 2016 USF Tampa, Team 9-5, Lacy Fall 2016人のメンバー
USFT-LACY-F16S9G5
4 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 11
今までの合計 1,121
