メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
はじめに
If you have continually received a lens error on your camera and restarting it doesn't help, then you need to replace the CCD lens. This guide walks you through the steps necessary to replace the CCD lens on the Nikon Coolpix S8200.
  1. First you must unscrew the back case by removing the two screws found on the bottom left and right of the camera as shown in the image.
    • First you must unscrew the back case by removing the two screws found on the bottom left and right of the camera as shown in the image.
    • Be careful not to remove any extra screws.
  2. The Essential Toolkit
    コンパクト版iFixitキットの中で最も利便性の高いツール
    ショップを見る
    ショップを見る
  3. Once the back is removed, Do Not remove the ribbon cables shown in the within the red circles on the image.
    • Once the back is removed, Do Not remove the ribbon cables shown in the within the red circles on the image.
  4. Unscrew the two screws around the silver disk-like part indicated by the red circles on the image and then remove them.
    • Unscrew the two screws around the silver disk-like part indicated by the red circles on the image and then remove them.
    • Next gently remove the black strap indicated by the yellow circle on the image.
    • The black strap can easily snap back on for reassembly.
終わりに
ある他の人がこのガイドを完成しました。
Nelson Antiposti
メンバー登録日: 2015年03月25日
499 ポイント
3のガイドは作成済み
チーム
UMass Dartmouth, Team 5-3, Kish Spring 2015 UMass Dartmouth, Team 5-3, Kish Spring 2015人のメンバー
UMASSD-KISH-S15S5G3
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 11
今までの合計 1,671
