メインコンテンツにスキップ
Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide
必要な工具と部品
  1. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: 手順 1、 2の画像 1 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Back Panel/Touch Screen: 手順 1、 2の画像 2
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 2、 2の画像 1 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 2、 2の画像 2
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
  3. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Motherboard: 手順 3、 1の画像 1
    • Unscrew all 6 visible screws that secure the motherboard into place using a Phillips head screwdriver (found in iFixit tool kit).
  4. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 4、 1の画像 1
    • Pull the shown panel off of the motherboard to expose the Image sensor connection
  5. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 5、 1の画像 1
    • Lift tab up to remove the Image sensor connection strip.
  6. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 6、 3の画像 1 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 6、 3の画像 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 6、 3の画像 3
    • Pull the gray panels back to allow the hidden micro usb and hdmi insert connectors to come free.
    • Use a Metal Spudger to help with the process to get these connectors free from the frame.
  7. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 7、 2の画像 1 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 7、 2の画像 2
    • Using a Metal Spudger, lift the motherboard up from the body of the camera.
  8. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 8、 2の画像 1 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide: 手順 8、 2の画像 2
    • Pull the motherboard off of the main body of the camera.
  9. Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: 手順 9、 3の画像 1 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: 手順 9、 3の画像 2 Nikon Coolpix S800c Zoom Unit/Shutter Replacement Guide, Zoom Unit/Shutter: 手順 9、 3の画像 3
    • Use a plastic opening tool of your choice to loosen and pry up the zoom unit/shutter component.
    • Use your hands to manually lift the zoom unit/shutter component up and out of the main body of the camera.
終わりに
作成者
2人の作成者と共同で作成されました。
Erik Knapton
メンバー登録日: 01/30/18
222 ポイント
2のガイドは作成済み
チーム
Baylor, Team S2-G6, Johnson Spring 2018 Baylor, Team S2-G6, Johnson Spring 2018人のメンバー
BU-JOHNSON-S18S2G6
3 メンバー
10のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 8
今までの合計 262
