はじめに
This guide will allow you to disassemble the camera to the point where the button assembly can be replaced, help you replace it and provide direction for reassembly.
必要な工具と部品
Turn the camera upside down and locate the two, black screws.
Using the Philips #00 Screwdriver, remove each screw.
Take the new button pad and orient it the same way as the old pad before it was removed.
Gently slide the end of the electric ribbon into the connector.
To make sure that the ribbon is completely in the connector give it a firm push but don't force anything. The ribbon should slide in with only a little resistance.
ある他の人がこのガイドを完成しました。
