はじめに
This guide will help you replace the jammed shutter button. The front cover of the camera needs to be removed. Once the front cover of the camera is removed, the shutter button can be easily removed and then replaced with a functioning shutter button.
パーツ
パーツは必要ありません。
  1. The battery compartment is located on the bottom of the camera.
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Slide the yellow tab towards the back of the camera.
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Press the memory card down into the camera.
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Free shipping on all orders over $100.00 or containing a Pro Tech Toolkit!
    当社のショップを閲覧する
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. Locate a small, rectangular flap above the battery cover door.
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  6. Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  7. Place the front cover facing down so that you can easily see the shutter button.
    • Place the front cover facing down so that you can easily see the shutter button.
  8. Using tweezers, gently slide the shutter button out.
    • Using tweezers, gently slide the shutter button out.
    • Be very gentle because you can damage the piece.
まとめ
Aulivia Bounchaleun
メンバー登録日: 2013年04月19日
10 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 8-56, Johann Spring 2013 Cal Poly, Team 8-56, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S8G56
4 メンバー
9のガイドは作成済み
統計データを表示:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,801
