メインコンテンツにスキップ
Nikon Coolpix S630 Back Cover Replacement
必要な工具と部品
  1. Nikon Coolpix S630 Back Cover Replacement, Battery Compartment: 手順 1、 1の画像 1
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Back Cover Replacement, Battery: 手順 2、 1の画像 1
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Back Cover Replacement, Memory Card: 手順 3、 1の画像 1
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: 手順 4、 3の画像 1 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: 手順 4、 3の画像 2 Nikon Coolpix S630 Back Cover Replacement, Back Cover Removal: 手順 4、 3の画像 3
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 Back Cover Replacement: 手順 5、 1の画像 1
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: 手順 6、 2の画像 1 Nikon Coolpix S630 Back Cover Replacement, Detaching Ribbon: 手順 6、 2の画像 2
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
終わりに
作成者
9人の作成者と共同で作成されました。
Anna Katrina
メンバー登録日: 04/18/13
28 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 8-56, Johann Spring 2013 Cal Poly, Team 8-56, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S8G56
4 メンバー
18のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 468
