はじめに
This guide will allow the reader to understand how to disassemble the Nikon Coolpix S5300 and get to its image sensor.
必要な工具と部品
Turn the camera upside down and locate the battery compartment.
Slide the compartment open following the direction of the arrow.
Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
Using the same screwdriver, remove the 2 screws on the side of the camera.
Remove the 2 screws from the other side of the camera.
Remove the 2 screws on the silver plate
Gently lift the screen and silver plate away from the internal components.
Carefully remove the screen away from the silver plate.
Carefully fold the screen over exposing the latch for the ribbon cable.
Using the phillips head screwdriver, remove the three 0.1mm screws on the metal plate.
Carefully remove metal plate from the camera.
