はじめに
This guide will allow the reader to how to disassemble the Nikon Coolpix S5300 and get to its button panel.
- Make sure to be gentle when removing ribbon cables.
- Be sure to keep track of all your screws.
必要な工具と部品
Turn the camera upside down and locate the battery compartment.
Slide the compartment open following the direction of the arrow.
Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
Using the same screwdriver, remove the 2 screws on the side of the camera.
Remove the 2 screws from the other side of the camera.
Remove the 2 screws on the silver plate
Gently lift the screen and silver plate away from the internal components.
