メインコンテンツにスキップ
Nikon Coolpix S4000 Motherboard Replacement
必要な工具と部品
  1. Nikon Coolpix S4000 Motherboard Replacement, Battery: 手順 1、 1の画像 1
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Nikon Coolpix S4000 Motherboard Replacement: 手順 2、 1の画像 1
    • Push the orange tab back and the battery will pop out.
  3. Nikon Coolpix S4000 Motherboard Replacement, Casing: 手順 3、 3の画像 1 Nikon Coolpix S4000 Motherboard Replacement, Casing: 手順 3、 3の画像 2 Nikon Coolpix S4000 Motherboard Replacement, Casing: 手順 3、 3の画像 3
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
  4. Nikon Coolpix S4000 Motherboard Replacement: 手順 4、 2の画像 1 Nikon Coolpix S4000 Motherboard Replacement: 手順 4、 2の画像 2
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
  5. Nikon Coolpix S4000 Motherboard Replacement: 手順 5、 3の画像 1 Nikon Coolpix S4000 Motherboard Replacement: 手順 5、 3の画像 2 Nikon Coolpix S4000 Motherboard Replacement: 手順 5、 3の画像 3
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
  6. Nikon Coolpix S4000 Motherboard Replacement, Lens Casing: 手順 6、 1の画像 1
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
  7. Nikon Coolpix S4000 Motherboard Replacement: 手順 7、 2の画像 1 Nikon Coolpix S4000 Motherboard Replacement: 手順 7、 2の画像 2
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
  8. Nikon Coolpix S4000 Motherboard Replacement, Screen: 手順 8、 1の画像 1
    • Remove the single 2mm Phillips #000 screw.
  9. Nikon Coolpix S4000 Motherboard Replacement: 手順 9、 3の画像 1 Nikon Coolpix S4000 Motherboard Replacement: 手順 9、 3の画像 2 Nikon Coolpix S4000 Motherboard Replacement: 手順 9、 3の画像 3
    • Use the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
  10. Nikon Coolpix S4000 Motherboard Replacement: 手順 10、 2の画像 1 Nikon Coolpix S4000 Motherboard Replacement: 手順 10、 2の画像 2
    • Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
  11. Nikon Coolpix S4000 Motherboard Replacement, Lens: 手順 11、 2の画像 1 Nikon Coolpix S4000 Motherboard Replacement, Lens: 手順 11、 2の画像 2
    • Remove the two 3mm Phillips #000 screws.
  12. Nikon Coolpix S4000 Motherboard Replacement: 手順 12、 2の画像 1 Nikon Coolpix S4000 Motherboard Replacement: 手順 12、 2の画像 2
    • Turn the camera over and remove a single 4mm Phillips #000 screw.
    • There may be black tape covering the screw.
  13. Nikon Coolpix S4000 Motherboard Replacement: 手順 13、 2の画像 1 Nikon Coolpix S4000 Motherboard Replacement: 手順 13、 2の画像 2
    • Use the flat end of a spudger to flip up the black tabs on the ZIF connectors.
  14. Nikon Coolpix S4000 Motherboard Replacement: 手順 14、 2の画像 1 Nikon Coolpix S4000 Motherboard Replacement: 手順 14、 2の画像 2
    • Use the flat end of a spudger to pry the lens locking tabs open while pulling the lens away from the camera body.
    • The tabs are brittle so use gently force.
  15. Nikon Coolpix S4000 Motherboard Replacement: 手順 15、 1の画像 1
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the orange ribbon cable out of the ZIF connector.
    • Separate the lens from the motherboard.
  16. Nikon Coolpix S4000 Motherboard Replacement, Motherboard: 手順 16、 1の画像 1
    • Remove the two Phillips #000 screws securing the motherboard.
  17. Nikon Coolpix S4000 Motherboard Replacement: 手順 17、 2の画像 1 Nikon Coolpix S4000 Motherboard Replacement: 手順 17、 2の画像 2
    • Pull the motherboard out.
終わりに
作成者
2人の作成者と共同で作成されました。
Matina Newsom
メンバー登録日: 02/21/18
779 ポイント
8のガイドは作成済み
チーム
University of North Texas, Team S4-G1, Thompson Spring 2018 University of North Texas, Team S4-G1, Thompson Spring 2018人のメンバー
UNT-THOMPSON-S18S4G1
5 メンバー
16のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 6
過去 30 日: 16
今までの合計 237
