はじめに
If the lense on your camera is malfunctioning we suggest first checking out our troubleshooting guide. If you have determined that the lense itself needs replacing please follow this guide to replace it.
Please note that this guide will require the use of a soldering tool to replace the lens completely.
必要な工具と部品
Remove four 2mm Phillips #000 screws.
Remove two black 3mm Phillips #000 screws.
Remove one 4mm Phillips #000 screws.
Remove two silver 3mm Phillips #000 screws.
ある他の人がこのガイドを完成しました。
