メインコンテンツにスキップ
Nikon Coolpix S3500 Rear Buttons Replacement
必要な工具と部品
  1. Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: 手順 1、 2の画像 1 Nikon Coolpix S3500 Rear Buttons  Replacement, Back Panel Disassembly: 手順 1、 2の画像 2
    • With the battery door facing upward, take your PH000 screwdriver and remove the 4 mm screws from the bottom of the device.
  2. Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 2、 2の画像 1 Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 2、 2の画像 2
    • After removing the screws, rotate the device to where the micro USB port is facing up.
    • Now, take your PH000 screwdriver and remove the two 4 mm screws from the device.
  3. Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 3、 2の画像 1 Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 3、 2の画像 2
    • Rotate the device 180 degrees so that the opposite side of the device is now facing upwards.
  4. Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 4、 2の画像 1 Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 4、 2の画像 2
    • After all of the screws are removed, rotate the device so that the bottom of the device is now facing upward.
    • With your index finger, press down and slide open the memory card/battery door.
  5. Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 5、 3の画像 1 Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 5、 3の画像 2 Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 5、 3の画像 3
    • Now take the plastic opening tool, and place it in the seam of the device.
    • Now, work the tool around the seam of the device until you can safely pry open the device.
  6. Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 6、 2の画像 1 Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 6、 2の画像 2
    • Be careful when removing the back piece of your device.
    • Using your free hand, finish prying off the back piece of the device.
  7. Nikon Coolpix S3500 Rear Buttons  Replacement, Rear Buttons: 手順 7、 1の画像 1
    • Take the rear panel of the device in the palm of your hand with the buttons facing downward.
  8. Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 8、 3の画像 1 Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 8、 3の画像 2 Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 8、 3の画像 3
    • On the back side of the device's rear panel, you will see the plastic brackets that hold the rear function buttons in place.
    • With your other hand, take the pry tool and start working your way around the edge of the buttons
  9. Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 9、 2の画像 1 Nikon Coolpix S3500 Rear Buttons  Replacement: 手順 9、 2の画像 2
    • Now, take the hand that was previously holding the pry tool, and finish pulling off the rear function buttons.
終わりに
作成者
1人の作成者と共同作成されました。
Jordan Rosemeyer
メンバー登録日: 10/13/15
491 ポイント
4のガイドは作成済み
チーム
Sam Houston State, Team 2-1, Blackburne Fall 2015 Sam Houston State, Team 2-1, Blackburne Fall 2015人のメンバー
SHSU-BLACKBURNE-F15S2G1
3 メンバー
7のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 11
今までの合計 421
