はじめに
If your camera won't respond to any efforts to turn on, you may need to replace the motherboard in the camera. This guide will walk you through how to replace the motherboard so that you can have a working camera again.
必要な工具と部品
Remove all four T5 Torx screws from the exterior of the camera.
Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
Remove all three 15'' Torx screws. Gently pry off the LCD holder using a plastic opening tool.
Peel off the connecting tape under the LCD holder to disconnect it completely.
5 の人々がこのガイドを完成させました。
