メインコンテンツにスキップ
Nikon Coolpix S3100 Camera Shutter Button Replacement
必要な工具と部品
  1. Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: 手順 1、 3の画像 1 Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: 手順 1、 3の画像 2 Nikon Coolpix S3100 Camera Shutter Button Replacement, Nikon Coolpix S3100 disassembly: 手順 1、 3の画像 3
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Shutter Button Replacement: 手順 2、 2の画像 1 Nikon Coolpix S3100 Camera Shutter Button Replacement: 手順 2、 2の画像 2
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Shutter Button Replacement: 手順 3、 2の画像 1 Nikon Coolpix S3100 Camera Shutter Button Replacement: 手順 3、 2の画像 2
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Shutter Button Replacement, Shutter Button: 手順 4、 1の画像 1
    • Turn and hold the shutter bottom to the left and using a tweezer carefully remove the spring.
    • Be very carefully handling the spring as it could release from tweezer.
  5. Nikon Coolpix S3100 Camera Shutter Button Replacement: 手順 5、 1の画像 1
    • Gently remove the black adhesive tape.
  6. Nikon Coolpix S3100 Camera Shutter Button Replacement: 手順 6、 1の画像 1
    • Remove 2-2.90mm using a #000 Phillips screwdriver.
  7. Nikon Coolpix S3100 Camera Shutter Button Replacement: 手順 7、 1の画像 1
    • The camera shutter is now apart.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jorge
メンバー登録日: 03/11/15
1,170 ポイント
7のガイドは作成済み
チーム
Colorado Springs, Team 2-4, Panko Spring 2015 Colorado Springs, Team 2-4, Panko Spring 2015人のメンバー
UCCS-PANKO-S15S2G4
2 メンバー
13のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 6
今までの合計 523
